Community Member
WLC 5508 intermittent loss of connectivity
Hi.
I have a WLC 5508 connecting directly to a distribution switch (3850) via a layer 2 etherchannel trunk fibre link with LAG enabled on the WLC.
Whenever there is a loss of power to the server room where both devices are hosted & power later gets restored, the distribution switch & WLC lose Layer 2 & 3 connectivity. Connectivity only gets restored when the WLC is power cycled or the fibre cables connecting to its SFP ports are removed & plugged back in. When this is done connectivity is restored between them, APs associate etc. Once there is a loss of power to the room for whatsoever reason again, the loss of connectivity issue re-occurs.
Disabled the etherchannel at some point, using only a single fibre trunk link between them, but the issue persists.
Also check for interface errors, CRCs, etc on both ends but there are none.
Can anyone please advice me on what the issue is & what can be done to permanently resolve this?
Thanks in anticipation.
Ope.
Hall of Fame Super Gold
Sounds like you have an ARP issue somewhere.  What happens if you "shut/no shut" the Port Channel interface?
Community Member
I doubt its an ARP issue because I looked into that.
When I do a "shut/no shut" on the switch it has no effect until the physical connection is either broken or the WLC is power cycled.
What version is the firmware of the 5508?
VIP Purple
Can you paste the config of swicth port where WLC connected ?
also paste the sh int <> from swicth.
what is the port setting on controller: it should be Fixed 1000 Mbps full duplex .
Dont forget to arte helpful posts
Community Member
Software version is 7.4.100.0
int gig1/0/5
  switchport mode trunk
  channel-group 1 mode on
int gig1/0/6
Port setting on the switch is set to auto-negotiate. Port setting on the controller is "auto". The link has been negotiated (& always negotiates) to 1000Mbps full duplex on both ends.
Presently in transit with no way of connecting to the device, but I checked the duplex & speed settings on both devices which was appropriately negotiated. Also checked for interface error counters on the switch, there was none. Checked the WLC logs too, there were no logs on issues with the interfaces or auto-negotiation.
Just to be on the safe side, I'd upgrade the firmware of your WLC to something more recent of the 7.4.X range.
Hall of Fame Super Silver
I don't know if it's an issue with the WLC, but like Leo mentioned, upgrade to v7.4.121.0 MR2.  It might be the switch and not being able to bring up the port channel.  If you only connect one port and you disable the port channel, does the problem go away or not?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
269
