WLC 5508 Web Auth and EAP / PEAP
   Morning all, I'm looking for some clarification.
Current setup:
I work in a school, a few years age I installed a 4400 WLC and several APs as a proof of concept exercise to see whether wireless technology would be of benefit to teaching and learning. It was deemed to be so.
This summer I installed 2 x 5508 WLCs and increased AP coverage to 50 - copied over the configs from the old controller - all works fine.
Currently only the staff can access the WLANs with the exception of a public WLAN in the canteen area.
Because there are a limited number of devices, WPA2 in conjunction with MAC filtering was used. However the school wants to open the wireless network to all of the students - potentially this means up to 1000 devices that will no doubt change on a regular basis so MAC filtering is out.
In line with child protection policies I need an 'auditable' trail when students access wireless resources.
Planned setup:
I have setup a test WLAN that uses Web Auth - the WLC is configured to pass authentication requests  ( through an ASA ) onto a RADIUS server which is tied into AD. I have a CA setup as well as a NAP server.
There is no layer 2 security set on the test WLAN and layer 3 is just web authentication. From any mobile device I can authenticate against AD and gain access to the Internet.
Clarification:
With no layer 2 security the WLAN is exposed so I need to introduce some form of end to end encryption - so I am looking at deploying EAP / PEAP.
Would the introduction of EAP / PEAP keep the network as secure as if I was using WPA2 ?
Many thanks.
  • Other Wireless - Mobility Subjects
If you are web authentication you cannot use dot1x as L2 security , so EAP is not an option.
But you can use preshared security , like WPA2 AES with web auth to insure that the traffic is encrypted.
or you can define a wlan profile with dot1x security on l2 and nothing on l3 , by doing so you would definetely hit the utmost security poossible.
Check the following link which contain couple of EAP config examples:
http://www.cisco.com/en/US/partner/tech/tk722/tk809/tech_configuration_examples_list.html
Please make sure to rate correct answers
Unfortunately I can't get to that document...but thaks anyway.
So can I use WPA2 with AES and 802.1x  that authenticates against the RADIUS Server?
299
