WLC 6 WLAN Override problem
works function WLAN Override in controller WLC6?, we have tried it and it does not work, is a software problem?
Re: WLC 6 WLAN Override problem
This has a bug in versions above 4.0.206. Just make sure your wlan profile names match the SSIDs. Then it works perfectly.
Bronze
Professorguy,
Does having to match profile name to SSID name result in not being able to have multiple authentication methods per SSID? That was supposed to be a feature of 4.0.206.
197
