WLC 7.4.110.0 failover problems (services not working anymore)
For some time now our WLC reboots after the message
Mar 13 00:19:09 WLC-HA-: *rmgrMain: Mar 13 00:19:09.986: #RMGR-3-RED_HEARTBEAT_TMOUT: rmgr_main.c:242 rmgrTmoHeartbeat: Recved GW ping count 6 phyMgr ping count 0.
Mar 13 00:19:10 WLC: *rmgrMain: Mar 13 00:19:10.185: #RMGR-0-RED_HA_RELOAD: rmgr_utils.c:188 System reboot: reason: category Peer reload req object Peer
we then get ip address conflicts (primary and standby unit)
Mar 13 00:19:10 WLC: *dtlArpTask: Mar 13 00:19:10.237: #DTL-1-IP_CONFLICT_DETECTED: dtl_net.c:4857 Network device with mac addr 00:07:7d:bf:94:4f using IP address of local interface 'management'. 10.10.10.5 - Received ARP Reply on interface 13 with vlan ID 0. IP conflict is detected
Mar 13 00:19:10
WLC: *dtlArpTask: Mar 13 00:19:10.239: #LOG-1-Q_IND: dtl_net.c:4857 Network device with mac addr 00:07:7d:bf:94:4f using IP address of local interface 'management'. 10.10.10.5 - Received ARP Reply on interface 13 with vlan ID 0. IP conflict is detected
Mar 13 00:19:10
WLC: *dtlArpTask: Mar 13 00:19:10.239: #DTL-1-IP_CONFLICT_DETECTED: dtl_net.c:4857 Network device with mac addr 00:07:7d:bf:94:4f using IP address of local interface 'eduroam2-wlan-dmz'. 5.5.5.7 - Received ARP Reply on interface 13 with vlan ID 33. IP conflict is de
Mar 13 00:19:10
WLC: *dtlArpTask: Mar 13 00:19:10.240: #DTL-1-IP_CONFLICT_DETECTED: dtl_net.c:4857 Network device with mac addr 00:07:7d:bf:94:4f using IP address of local interface 'eduroam-wlan-dmz'. 5.5.6.7 - Received ARP Reply on interface 13 with vlan ID 34. IP conflict is det
Mar 13 00:19:10
WLC: *dtlArpTask: Mar 13 00:19:10.282: #DTL-1-IP_CONFLICT_DETECTED: dtl_net.c:4857 Network device with mac addr 00:07:7d:bf:95:6f using IP address of local interface 'management'. 10.10.10.5 - Received ARP Reply on interface 13 with vlan ID 0. IP conflict is detected
after this failover 2 severe problems occur:
  • The wlc does not send radius packets anymore (from the eduroam interfaces).
  • The wlc "forgets" the "guest lan" on an interface and as subsequent issue this interface is deleted as ingrees interface of a "Guest LAN"
if we upgrade to 7.4.121.0 and i do the setting "config redundancy management-gateway-failover disable" as described in this thread then the error would still occur on another failover reason.
any ideas on this issues?
regards
-andreas
VIP Purple
Hi,#DTL-1-IP_CONFLICT
The IP address of one of the interfaces on the switch is being used by another network element. Please find out the other device which is using the same IP.
If still fails then raise a TAC case.
Dont forget to rate helpful posts
The other device is the 2nd
The other device is the 2nd WLC...
347
