WLC 7.5 Sleeping clients with ISE and Central WEB Auth(CWA)
Hi there,
Is it possibe to use sleeping clients when using ISE and CWA?
I was thinking of enabling layer3 auth with web auth on mac auth failure, but will that work with CWA?
Or is the only solution to use LWA?
Re:WLC 7.5 Sleeping clients with ISE and Central WEB Auth(CWA)
I have not tried said solution, but the premise behind sleeping client is that the controller doesn't end the client session.
With CWA, once you have achieved the RUN state you should remain in the RUN state until the sleeping client timer expires.
Sent from Cisco Technical Support Android App
The question is, how do you enable sleeping Clients when use CWA?
CWA works without enabling layer 3 auth on the controller.
Re: Re:WLC 7.5 Sleeping clients with ISE and Central WEB Auth(CW
Any updates? Is this possible with cwa?
I asked TAC, and it is not possible to use sleeping clients with CWA.
We switched to LWA and that works.
Controller-> General-> User Idle Timeout (seconds) = 50 000 sec.
And your users will be connected all this time even if they going in sleepmode
be carefull with CPU loading
what is safe number of
what is safe number of seconds with ~500 wifi devices on vwlc? We want to use CWA for BYOD mobile devices..
1553
