09-04-2014 02:30 AM - edited 07-05-2021 01:29 AM
Is there a way of getting a count of how many APs are in an APGROUP either via CLI or GUI .
This is for a confidence check. I can get a count of all APs with a certain name that should be in an APGROUP, but how do I see a count total how many are actually in that APGROUP?
In the GUI using tab WLANs then ADVANCED, does not give a count total.
Even a print out on the cli matching AP name to APGROUP name would do.
Solved! Go to Solution.
09-04-2014 09:44 AM
Click on configure > Controller , then click on ip of specific WLC and then on left side click on WLAN configuration, under this tab you will see how many AP Groups.
Now if you click on configured AP then you can see how many APS are there.
Dont forget to rate helpful posts
09-04-2014 02:49 AM
try this command: sh wlan apgroups
09-04-2014 04:09 AM
Sandeep
Thanks for that, and while I can use that command then copy in to a text editor and count how many lines of APs in a certain APGROUP, I have 60 APGROUPS and some of those groups may have 200 APs within them.
This is quite a long winded way of checking that 60 APGROUPS have the correct number of APs in them, which I need to do at the end of our deployment.
09-04-2014 04:17 AM
I dont think thata there is anyother way by WLC.
If you have WCS or NCS then you can check easily by going to Controller and then click on ip of the controller , then WLANs > AP Groups
09-04-2014 09:22 AM
I have CPI, is there a way using that?
09-04-2014 09:44 AM
09-05-2014 05:10 AM
That is exactly it,thanks for your assistance.
