Community Member
WLC AIR-CT5508-K9 7.4.121.0 Reason: System Crash, Task Name: emWeb
today one of our customers WLC 5508 with code version 7.4.121.0 crashed. the uptime was around 50days and there we're no bigged changes since then.
from the crashinfo i can assume that the "EmWeb" process was involved in the crash... are there any related bug's to this process?
Number of files present is: 12
Beginning of Crash File: mwar_dump2.crash
 Dumping registers
CPU Registers:
$ 0   : 00000000 1000cce1 fefe0000 80808080
$ 4   : 00000000 00000000 00000000 fefefeff
$ 8   : 5665121c 13511404 134923f0 00000012
$12   : 00000035 00000004 00000000 00000001
$16   : 00000020 00000000 00000000 1626eaa0
$20   : 143f9048 2b68dfb8 143f9048 13541404
$24   : 00000000 120757b0
$28   : 13511404 56651480 566514d0 10afcd58
Hi    : 00000000
Lo    : cccccccd
Stack :
        00000000 1626e600 00000000 00000000
        ffffffff ffffffff 00000000 13541404
        00000000 13511404 00000000 10bac71c
        00000000 2b68df44 00000000 2b68df44
        00000000 13511404 00000000 10dbffc0
        2b68df44 00000002 00000005 12232e50
        2b68df44 00000002 00000000 12233458
        00000000 13511404 00000000 56651510
        00000000 1144e004 00000000 1144d118
        00000000 00000000 2b6926b8 00000000
        00000000 00000000 c0a81291 00000000
        00000000 00000000 00000000 00000000
*             Start Cisco Crash Handler                *
Sys Name:  WLC
Model:     AIR-CT5508-K9
Version:   7.4.121.0
Timestamp: Tue Sep  2 09:09:45 2014
SystemUpTime:  0 days 0 hrs 33 mins 31 secs
signal:    11
pid:       1089
TID:       1449472848
Task Name: emWeb
si_signo:  11
si_errno:  0
si_code:   1
si_addr:   0x0
timer tcb:   0x966
timer cb:    0x106232f0 ('rrmTimerInit+592')
timer arg1:  0x379632d0
timer arg2:  0x0
Long time taken timer call back inforamtion:
Time Stamp:  Tue Sep  2 09:09:45 2014
timer cb  :  106232f0p('rrmTimerInit+592')
Duration  : 54483 usecs, cbCount= 1
Analysis of Failure:
  Software Failed on instruction at :
 pc = 0x12075800 (osapiStrlcpy+72), ra = 0x10afcd58 (osapiStrlcpy+72)
  Software Failed while accessing the data located at :0x0
System Stack
Frame 0: 0x10012c20 create_crash_dump+7156
Frame 1: 0x10011a18 create_crash_dump+2540
Frame 2: 0x10007ab8 sigsegv_handler+6168
Frame 3: 0x56651150 license_xos_thread_create+1149516832
Frame 4: 0x12075800 license_xos_thread_create+2523856
Frame 5: 0x10afcd58 osapiStrlcpy+72
Frame 6: 0x10bac71c simSetTransferUsername+100
Frame 7: 0x10dbffc0 usmDbTransferUsernameSet+68
Frame 8: 0x1144e004 ewaFormSubmit_file_upload+4068
Frame 9: 0x10a8f050 ewsServeSubmitForm+48
Frame 10: 0x10a8512c ewsParse+9180
Frame 11: 0x10a804a0 ewsRun+1240
Frame 12: 0x10a6f2fc ewmain+1764
Frame 13: 0x10a98c70 emweb_main+416
Frame 14: 0x10b0e858 osapiTaskAppKeySelfSet+304
Frame 15: 0x120292b0 license_xos_thread_create+2211200
Frame 16: 0x12089c4c license_xos_thread_create+2606876
Semaphore and Mutex Usage
(Caller IP(instruction pointer of caller) Gives one more level
 of depth in stack to track the Semaphore and Mutex operation)
 FIXME: semaphore count(17746) is greater then SEM_COUNT_LIMIT(16384) , time to increase the limit    Mutex 'pgrp->groupingSem' @ 0x18bdbe5c  Created fp_main_task(rrmgroup.c:1255)
      Locked by RRM-MGR-5_0-GRP(rrmgroup.c:1348), Caller IP = 0x10b0e858 (osapiTaskAppKeySelfSet+304)
      1 tasks waiting for resource.
Stackdump from RRM-MGR-5_0-GRP
Frame 0: 0x10007fac sighup_handler+116
Frame 1: 0x4d1ab680 license_xos_thread_create+993648976
Frame 2: 0x1202ecac license_xos_thread_create+2234236
Frame 3: 0x1202b764 license_xos_thread_create+2220596
Frame 4: 0x10b00838 osapiMutexTake+928
Frame 5: 0x105dc430 groupCalcEntry+360
Frame 6: 0x10b0e858 osapiTaskAppKeySelfSet+304
Frame 7: 0x120292b0 license_xos_thread_create+2211200
Frame 8: 0x12089c4c license_xos_thread_create+2606876
          RRM-MGR-5_0-GRP, rrmgroup.c:1348, Caller IP = 0x10b0e858 (osapiTaskAppKeySelfSet+304)
   Mutex 'pgrp->groupingSem' @ 0x18bdc090  Created fp_main_task(rrmgroup.c:1255)
      Locked by RRM-MGR-2_4-GRP(rrmgroup.c:1348), Caller IP = 0x10b0e858 (osapiTaskAppKeySelfSet+304)
Stackdump from RRM-MGR-2_4-GRP
Frame 1: 0x4c1df680 license_xos_thread_create+977084752
          RRM-MGR-2_4-GRP, rrmgroup.c:1348, Caller IP = 0x10b0e858 (osapiTaskAppKeySelfSet+304)
   Memory Information
System Memory Information:
             Total System Memory: 1027309568 bytes (979.78 Mb)
              Used System Memory: 509685760 bytes (486.10 Mb)
              Free System Memory: 517623808 bytes (493.68 Mb)
Heap information:
         Bytes alloced from RTOS: 19870528 bytes (18.95 Mb)
                     Chunks free: 15 bytes
       Number of mmapped regions: 59
  Total space in mmapped regions: 311734272 bytes (297.31 Mb)
           Total allocated space: 18677720 bytes (17.81 Mb)
           Total non-inuse space: 1192808 bytes (1.13 Mb)
      Top-most, releasable space: 92024 bytes (89.86 Kb)
     Total allocated (incl mmap): 331604800 bytes (316.26 Mb)
          Total used (incl mmap): 330411992 bytes (315.12 Mb)
          Total free (incl mmap): 1192808 bytes (1.13 Mb)
  Buffer Pooled Malloc Usage
Pool[00]: 16 byte chunks
    chunks in pool:    50000
    chunks in use:     11426
    bytes in use:      182816
    bytes requested:   111496 (71320 overhead bytes)
Pool[01]: 64 byte chunks
    chunks in pool:    40000
    chunks in use:     7275
    bytes in use:      465600
    bytes requested:   220149 (245451 overhead bytes)
Pool[02]: 128 byte chunks
    chunks in pool:    20000
    chunks in use:     1882
    bytes in use:      240896
    bytes requested:   150938 (89958 overhead bytes)
Pool[03]: 256 byte chunks
    chunks in pool:    3000
    chunks in use:     650
    bytes in use:      166400
    bytes requested:   143805 (64835 overhead bytes)
Pool[04]: 384 byte chunks
    chunks in pool:    6000
    chunks in use:     544
    bytes in use:      208896
    bytes requested:   143466 (65430 overhead bytes)
Pool[05]: 512 byte chunks
    chunks in pool:    18900
    chunks in use:     18853
    bytes in use:      9652736
    bytes requested:   8084254 (1568482 overhead bytes)
Pool[06]: 1024 byte chunks
    chunks in pool:    3500
    chunks in use:     234
    bytes in use:      239616
    bytes requested:   194547 (45069 overhead bytes)
Pool[07]: 2048 byte chunks
    chunks in pool:    1000
    chunks in use:     89
    bytes in use:      182272
    bytes requested:   122047 (60225 overhead bytes)
Pool[08]: 4096 byte chunks
    chunks in use:     59
    bytes in use:      241664
    bytes requested:   172630 (69034 overhead bytes)
Max number of Mbufs:     4608
number of Mbufs Free:    4594
number of Mbufs In Use:  14
   Interrupt Status
      Name            Total Interupts   PerSecond
 7: timer               5045514          2499
40: mailbox0           11012535          3253
42: serial                  224             0
43: serial                   23             0
48: MSI[0:63]             44278            23
   Octeon Device Status
oct0      Link encap:Ethernet  HWaddr 00:00:00:00:00:00
          inet6 addr: fe80::200:ff:fe00:0/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:48579 errors:0 dropped:0 overruns:0 frame:0
          TX packets:34223 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:13918302 (13.2 MiB)  TX bytes:0 (0.0 B)
-- Config Regs----
config[0]: 0050177d
config[4]: 00100546
config[8]: 0b300009
config[c]: 00000010
config[10]: f401000c
config[14]: 00000000
config[18]: f000000c
config[1c]: 00000000
config[20]: 0000000c
config[24]: 00000000
config[28]: 00000000
config[2c]: 0001177d
config[30]: 00000000
config[34]: 00000040
config[38]: 00000000
config[3c]: 0000012e
config[40]: 00035001
config[44]: 00000000
config[48]: 00000000
config[4c]: 00000000
config[50]: 00817005
config[54]: 00003cb0
config[58]: 00000000
config[5c]: 00000003
config[e0]: 00000000
Octeon BAR0 Registers
[200] (WIN_WR_ADDR_LO): 00000700
[204] (WIN_WR_ADDR_HI): 00000700
[210] (WIN_RD_ADDR_LO): 80000000
[214] (WIN_RD_ADDR_HI): 00011800
[220] (WIN_WR_DATA_LO): 00000ffe
[224] (WIN_WR_DATA_HI): 00000000
[230] (WIN_WR_MASK_REG): 00000000
[540] (INT_ENABLE): 0005e7ff
[530] (INT_SUM): 10000000
[5e0] (DMA_CNT_0): 00000000
[5c0] (DMA_INT_LEV_0): 00000000
[5c4] (DMA_TIME_0): 00000000
[5e4] (DMA_CNT_0): 00000000
[5d0] (DMA_INT_LEV_0): 00000000
[5d4] (DMA_TIME_0): 00000000
[0] (BAR1_INDEX_00): 0000000b
[10] (BAR1_INDEX_01): 0000001b
[20] (BAR1_INDEX_02): 0000002b
[30] (BAR1_INDEX_03): 0000003b
[40] (BAR1_INDEX_04): 0000004b
[50] (BAR1_INDEX_05): 0000005b
[60] (BAR1_INDEX_06): 0000006b
[70] (BAR1_INDEX_07): 0000007b
[80] (BAR1_INDEX_08): 0000008b
[90] (BAR1_INDEX_09): 0000009b
[a0] (BAR1_INDEX_10): 000000ab
[b0] (BAR1_INDEX_11): 000000bb
[c0] (BAR1_INDEX_12): 000000cb
[d0] (BAR1_INDEX_13): 000000db
[e0] (BAR1_INDEX_14): 000000eb
[f0] (BAR1_INDEX_15): 000000fb
[100] (BAR1_INDEX_16): 00000000
[110] (BAR1_INDEX_17): 00000000
[120] (BAR1_INDEX_18): 00000000
[130] (BAR1_INDEX_19): 00000000
[140] (BAR1_INDEX_20): 00000000
[150] (BAR1_INDEX_21): 00000000
[160] (BAR1_INDEX_22): 00000000
[170] (BAR1_INDEX_23): 00000000
[180] (BAR1_INDEX_24): 00000000
[190] (BAR1_INDEX_25): 00000000
[1a0] (BAR1_INDEX_26): 00000000
[1b0] (BAR1_INDEX_27): 00000000
[1c0] (BAR1_INDEX_28): 00000000
[1d0] (BAR1_INDEX_29): 00000000
[1e0] (BAR1_INDEX_30): 00000000
[1f0] (BAR1_INDEX_31): 00000000
Octeon (Status: RUNNING)
jiffies: 4295397149
--Instruction Queue--       IQ 0        IQ 1        IQ 2        IQ 3
 Instr processed   :     34225           0           0           0
 Instr dropped     :         0           0           0           0
 Bytes Sent        :   8166283           0           0           0
 sgentry_sent      :         0           0           0           0
 Inst Cnt reg      :      85b1           0           0           0
 Bytes since last  :   8166283           0           0           0
 Total Bytes since last:   8166283
__________________________________________________________________________
--DROQ--                  DROQ 0      DROQ 1      DROQ 2      DROQ 3
 Pkts Received      :      1916       46677           0           0
 Bytes Received     :   1113020    12807564           0           0
 Bytes since last   :   1113020    12807564           0           0
 Total Bytes since last:  13920584
 Pkts dropped
        No dispatch :        12           0           0           0
        No memory   :         0           0           0           0
        Too many    :         0           0           0           0
 Pending free index: 0
Chip Id: 0x5008  Status: 10 (RUNNING)
Interrupt Mask: 0x21fffffe0005e7ff  Interrupts: 44312
IQ 0 status
IQ Size: 1024 commands  Pending: 0 Back-pressure drop- ctrl:0 data:0
Index  Write: 433  Read: 433 Flush: 433
Register InstrCnt: 34225 DoorBell: 0
Fill Count: 0 Threshold: 1
IQ 1 status
IQ Size: 128 commands  Pending: 0 Back-pressure drop- ctrl:0 data:0
Index  Write: 0  Read: 0 Flush: 0
Register InstrCnt: 0 DoorBell: 0
IQ 2 status
IQ 3 status
DROQ 0 status
DROQ Size: 1024 Packets Pending: 0 Refill Count: 63
Index  Read: 892 Refill: 829
Register PktsSent: 0 PktsCredit: 0x00000383
DROQ 1 status
DROQ Size: 1024 Packets Pending: 0 Refill Count: 36
Index  Read: 597 Refill: 561
Register PktsSent: 0 PktsCredit: 0x000003a0
DROQ 2 status
DROQ Size: 1024 Packets Pending: 0 Refill Count: 0
Index  Read: 0 Refill: 0
Register PktsSent: 0 PktsCredit: 0x000003c0
DROQ 3 status
Task Summary
 Name               Priority   Policy  BytesInUse  BlocksInUse     CPU (usr/sys)  hwm  CPU   Reaper
 LICENSE AGENT      (240/  7)    RR             0            0       0 (  0/  0)%   0   8   I
 System Reset Task  (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 reaperWatcher      (  3/ 96)    RR             0            0       0 (  0/  0)%   0   8   I
 osapiReaper        ( 10/ 94)    RR             0            0       0 (  0/  0)%   0   8   I
 TempStatus         (240/  7)    RR           428            1       0 (  0/  0)%   0   1   I
 HAPeerToPeerCommTa ( 90/ 64)    RR         41175            4       0 (  0/  0)%   0   5
 pktDebugSocketTask (255/  1)    RR             0            0       0 (  0/  0)%   0   4
 webauthRedirect    (240/  7)    RR         11202            3       0 (  0/  0)%   0   3
 emWeb              (240/  7)    RR        246464         2223      94 (  0/ 94)%  94   6   T 290
 Bonjour_Socket_Tas (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 Bonjour_Process_Ta (174/ 32)    RR             0            0       0 (  0/  0)%   0   2
 Bonjour_Msg_Task   (174/ 32)    RR             0            0       0 (  0/  0)%   0   2
 portalMonitorMsgTa (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 portalMsgTask      (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 portalSockTask     (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 PMIPV6 Thread      (240/  7)    RR          2618           17       0 (  0/  0)%   0   8
 PMIPV6 Thread      (240/  7)    RR          2618           17       0 (  0/  0)%   0   2
 PMIPV6 Thread      (240/  7)    RR          5242           35       0 (  0/  0)%   0   2
 hotspotTask        (100/ 60)    RR             0            0       0 (  0/  0)%   0   2
 HAConfigSyncTask   (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 ipv6SocketTask     (240/  7)    RR             0            0       0 (  0/  0)%   0   7
 IPv6_Msg_Task      (174/ 32)    RR          1728           27       0 (  0/  0)%   0   3
 sisfSwitcherTask   (174/ 32)    RR         59724          400       0 (  0/  0)%   0   4
 SISF BT Process    (174/ 32)    RR         10360          140       0 (  0/  0)%   0   5
 SISF Feature Proce (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 fmcHsTask          (100/ 60)    RR             0            0       0 (  0/  0)%   0   2
 alarmMsgTask       (240/  7)    RR             0            0       0 (  0/  0)%   0   4
 SXP SOCK           (240/  7)    RR             0            0       0 (  0/  0)%   0   4   T 300
 SXP CORE           (240/  7)    RR             0            0       0 (  0/  0)%   0   5
 apstatEngineTask   (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 rrcEngineTask      (240/  7)    RR             0            0       0 (  0/  0)%   0   9
 wipsTask           (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 spectrumNMSPTask   (255/  1)    RR         28808            3       0 (  0/  0)%   0   8
 spectrumDataTask   (255/  1)    RR       5842204           12       0 (  0/  0)%   0   6
 ethoipOsapiMsgRcv  (240/  7)    RR             0            0       0 (  0/  0)%   0   1
 ethoipSocketTask   (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 cids-cl Task       (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 tsmTask            (255/  1)    RR             0            0       0 (  0/  0)%   0   2
 envCtrollerStatus  (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 rfidTask           (240/  7)    RR             0            0       0 (  0/  0)%   0   1
 idsTrackEventTask  (239/  8)    RR             0            0       0 (  0/  0)%   0   4
 DHCP Server        (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 bcastReceiveTask   (240/  7)    RR             0            0       0 (  0/  0)%   0   1
 ProcessLoggingTask (240/  7)    RR             0            0       0 (  0/  0)%   0   6
 CDP Main           (240/  7)    RR          3100           13       0 (  0/  0)%   0   5
 cdpSocketTask      (240/  7)    RR             0            0       0 (  0/  0)%   0   3
 sntpMainTask       (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 sntpReceiveTask    (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 rrmPeriodicTask    (255/  1)    RR             0            0       0 (  0/  0)%   0   8
 RRM-MGR-5_0        (255/  1)    RR             0            0       0 (  0/  0)%   0   9
 RRM-MGR-5_0-GRP    (255/  1)    RR             0            0       0 (  0/  0)%   2   7
 RRM-MGR-5_0-SOC    (255/  1)    RR          7939            4       0 (  0/  0)%   0   7
 RRM-DCLNT-5_0      (255/  1)    RR             0            0       0 (  0/  0)%   0   1
 RRM-CLNT-5_0       (255/  1)    RR             0            0       0 (  0/  0)%   0   9
 RRM-CLNT-5_0-SOC   (255/  1)    RR          7939            4       0 (  0/  0)%   0   9
 RRM-MGR-2_4        (255/  1)    RR             0            0       0 (  0/  0)%   0   9
 RRM-MGR-2_4-GRP    (255/  1)    RR             0            0       0 (  0/  0)%   0   6
 RRM-MGR-2_4-SOC    (255/  1)    RR          7939            4       0 (  0/  0)%   0   7
 RRM-DCLNT-2_4      (255/  1)    RR             0            0       0 (  0/  0)%   0   3
 RRM-CLNT-2_4       (255/  1)    RR             0            0       0 (  0/  0)%   0   9
 RRM-CLNT-2_4-SOC   (255/  1)    RR          7939            4       0 (  0/  0)%   0   9
 Radius Client Prof (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 apf80211vTask      (240/  7)    RR             0            0       0 (  0/  0)%   0   3
 apf80211KTask      (240/  7)    RR             0            0       0 (  0/  0)%   0   3
 RLDP Schedule Task (240/  7)    RR             0            0       0 (  0/  0)%   0   3
 Apf Guest          (240/  7)    RR             0            0       0 (  0/  0)%   0   9
 apfPmkCacheTimer   (240/  7)    RR             0            0       0 (  0/  0)%   0   7
 apfMsConnTask_7    (175/ 32)    RR             0            0       0 (  0/  0)%   0   1
 apfMsConnTask_6    (175/ 32)    RR             0            0       0 (  0/  0)%   0   5
 apfMsConnTask_5    (175/ 32)    RR             0            0       0 (  0/  0)%   0   3
 apfMsConnTask_4    (175/ 32)    RR             0            0       0 (  0/  0)%   0   4
 apfMsConnTask_3    (175/ 32)    RR             0            0       0 (  0/  0)%   0   3
 apfMsConnTask_2    (175/ 32)    RR             0            0       0 (  0/  0)%   0   5
 apfMsConnTask_1    (175/ 32)    RR             0            0       0 (  0/  0)%   0   2
 apfMsConnTask_0    (175/ 32)    RR             0            0       0 (  0/  0)%   0   9
 apfLbsTask         (240/  7)    RR             0            0       0 (  0/  0)%   0   3
 apfRogueTask_3     (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 apfRogueTask_2     (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 apfRogueTask_1     (240/  7)    RR             0            0       0 (  0/  0)%   0   9
 apfRogueTask_0     (240/  7)    RR             0            0       0 (  0/  0)%   0   9
 apfProbeThread     (200/ 22)    RR         46224          108       0 (  0/  0)%   0   1
 apfOrphanSocketTas (240/  7)    RR         10580           94       0 (  0/  0)%   0   3
 apfRogueDetectorTh (175/ 32)    RR             0            0       0 (  0/  0)%   0   2
 apfOpenDtlSocket   (175/ 32)    RR             0            0       0 (  0/  0)%   0   1
 apfRLDP            (175/ 32)    RR           428            1       0 (  0/  0)%   0   8
 apfRLDPRecv        (175/ 32)    RR             0            0       0 (  0/  0)%   0   8
 apfReceiveTask     (175/ 32)    RR         21400           50       0 (  0/  0)%   0   5
 NBAR2_Task         (240/  7)    RR        721079         1522       0 (  0/  0)% 100   9
 NFV9_Task          (240/  7)    RR        475970            4       0 (  0/  0)%   0   9
 mmMfpTask          (175/ 32)    RR             0            0       0 (  0/  0)%   0   4
 mmMobility         (240/  7)    RR          1712            4       0 (  0/  0)%   0   1
 mmSSHPeerRegister  (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 mmListen           (180/ 30)    RR          4096            1       0 (  0/  0)%   0   8
 EAP Framework      (240/  7)    RR             0            0       0 (  0/  0)%   0   5
 wapi daemon        (240/  7)    RR          2653          108       0 (  0/  0)%   0   5
 aaaQueueReader     (225/ 13)    RR             0            0       0 (  0/  0)%   0   2
 tplusTransportThre (201/ 22)    RR             0            0       0 (  0/  0)%   0   6   T 300
 radiusCoASupportTr (201/ 22)    RR             0            0       0 (  0/  0)%   0   6
 radiusRFC3576Trans (201/ 22)    RR             0            0       0 (  0/  0)%   0   3
 radiusTransportThr (201/ 22)    RR             0            0       0 (  0/  0)%   0   7
 pemReceiveTask     (240/  7)    RR             0            0       0 (  0/  0)%   0   3
 ewmwebWebauth1     (240/  7)    RR             0            0       0 (  0/  0)%   0   4
 iappSocketTask     (240/  7)    RR             0            0       0 (  0/  0)%   0   1
 ccxS69Task         (240/  7)    RR           428            1       0 (  0/  0)%   0   6
 ccxRmTask          (230/ 11)    RR             0            0       0 (  0/  0)%   0   9
 ccxDiagTask        (240/  7)    RR             0            0       0 (  0/  0)%   0   4
 ccxL2RoamTask      (240/  7)    RR        180980            4       0 (  0/  0)%   0   4
 dot1xSocketTask    (240/  7)    RR             0            0       0 (  0/  0)%   0   5
 Dot1x_NW_MsgTask_7 (240/  7)    RR          8080            5       0 (  0/  0)%   0   5
 Dot1x_NW_MsgTask_6 (240/  7)    RR          5544            4       0 (  0/  0)%   0   2
 Dot1x_NW_MsgTask_3 (240/  7)    RR          5544            4       0 (  0/  0)%   0   2
 Dot1x_NW_MsgTask_4 (240/  7)    RR          3008            3       0 (  0/  0)%   0   2
 Dot1x_NW_MsgTask_5 (240/  7)    RR          2536            1       0 (  0/  0)%   0   4
 Dot1x_NW_MsgTask_2 (240/  7)    RR             0            0       0 (  0/  0)%   0   4
 Dot1x_NW_MsgTask_1 (240/  7)    RR          8552            7       0 (  0/  0)%   0   5
 Dot1x_NW_MsgTask_0 (240/  7)    RR         13624            9       0 (  0/  0)%   0   5
 dot1xMsgTask       (240/  7)    RR             0            0       0 (  0/  0)%   0   9
 capwapHATask       (100/ 60)    RR             0            0       0 (  0/  0)%   0   3
 nmspRxServerTask   (200/ 22)    RR         15234          576       0 (  0/  0)%   0   2
 nmspTxServerTask   (220/ 15)    RR             0            0       0 (  0/  0)%   0   7
 capwapSocketTask   (118/ 53)    RR             0            0       0 (  0/  0)%   0   7
 spamApTask4        (118/ 53)    RR         94003          979       0 (  0/  0)%  12   4
 spamApTask5        (118/ 53)    RR        276309         2914       0 (  0/  0)%   3   5
 spamApTask6        (118/ 53)    RR         94003          979       0 (  0/  0)%  14   4
 spamApTask7        (118/ 53)    RR        462039         4857       0 (  0/  0)%  13   7
 spamApTask3        (118/ 53)    RR        460319         4853       0 (  0/  0)%   3   5
 spamApTask2        (118/ 53)    RR        186694         1973       0 (  0/  0)%  15   9
 spamApTask1        (118/ 53)    RR        275881         2913       0 (  0/  0)%   0   8
 spamApTask0        (118/ 53)    RR        493523         4855       0 (  0/  0)%   7   5
 spamReceiveTask    (120/ 52)    RR       2318028          503       0 (  0/  0)%   0   4
 spamSocketTask     (175/ 32)    RR             0            0       0 (  0/  0)%   0   8
 sshpmLscScepTask   (100/ 60)    RR             0            0       0 (  0/  0)%   0   9
 License Client Lib (240/  7)    RR             0            0       0 (  0/  0)%   0   1   I
 IPC control Receiv (240/  7)    RR             0            0       0 (  0/  0)%   0   6   I
 IPC Main Thread    (240/  7)    RR             0            0       0 (  0/  0)%   0   8   I
 sshpmLscTask       (100/ 60)    RR         23483         1558       0 (  0/  0)%   0   9
 sshpmReceiveTask   (175/ 32)    RR          6745           73       0 (  0/  0)%   0   9
 sshpmMainTask      (100/ 60)    RR        204849          356       0 (  0/  0)%   0   4
 mfpKeyRefreshTask  (255/  1)    RR             0            0       0 (  0/  0)%   0   4
 mfpTrapForwardTask (255/  1)    RR             0            0       0 (  0/  0)%   0   7
 mfpEventTask       (255/  1)    RR             0            0       0 (  0/  0)%   0   5
 clientTroubleShoot (100/ 60)    RR       2841256            4       0 (  0/  0)%   0   5
 loggerMainTask     (200/ 22)    RR             0            0       0 (  0/  0)%   0   2
 debugMainTask      (200/ 22)    RR             0            0       0 (  0/  0)%   0   5
 dot3ad_lac_task    (240/  7)    RR         32901            3       0 (  0/  0)%   0   3
 gccp_t             (240/  7)    RR          5868            5       0 (  0/  0)%   0   7
 dot1dTimer         (240/  7)    RR             0            0       0 (  0/  0)%   0   1   T 300
 dot1dRecv          (250/  3)    RR             0            0       0 (  0/  0)%   0   1
 fdbTask            (240/  7)    RR             0            0       0 (  0/  0)%   0   1
 uart_session       (240/  7)    RR             0            0       0 (  0/  0)%   0   7
 broffu_SocketRecei (100/ 60)    RR         13453           27       0 (  0/  0)%   0   2
 StatsTask          (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 SNMPProcMon        (240/  7)    RR             0            0       0 (  0/  0)%   0   6   T 300
 RMONTask           (240/  7)    RR             0            0       0 (  0/  0)%   0   9   I
 snmp_trap_msg_task (100/ 60)    RR        188544            3       0 (  0/  0)%   0   6
 SNMPTask           (240/  7)    RR         12790          232       0 (  0/  0)%   0   3
 DHCP Socket Task   (240/  7)    RR             0            0       0 (  0/  0)%   0   7
 DHCP Proxy Task    (240/  7)    RR             0            0       0 (  0/  0)%   0   8
 BootP              (240/  7)    RR             0            0       0 (  0/  0)%   0   9   T 300
 dhcpClientTimerTas (240/  7)    RR             0            0       0 (  0/  0)%   0   6
 DHCP Client Task   (240/  7)    RR             0            0       0 (  0/  0)%   0   3   T 600
 TransferTask       (240/  7)    RR          1284            3       0 (  0/  0)%   0   5   I
 osapiTimer         (100/ 60)    RR         13028            2       0 (  0/  0)%   0   8   T 300
 sim_task           (100/ 60)    RR          2447            3       0 (  0/  0)%   0   5   I
 nim_t              (100/ 60)    RR          2447            3       0 (  0/  0)%   0   5
 dtlDataLowTask     (240/  7)    RR             0            0       0 (  0/  0)%   0   3
 greTask            (100/ 60)    RR             0            0       0 (  0/  0)%   0   3
 dtlArpTask         (240/  7)    RR         98436            3       0 (  0/  0)%   0   3
 dtlTask            (100/ 60)    RR         41089            3       0 (  0/  0)%   0   5
 sampStatsTask      (240/  7)    RR             0            0       0 (  0/  0)%   0   2
 sysapiprintf       (240/  7)    RR         22657            3       0 (  0/  0)%   0   3
 osapiBsnTimer      ( 70/ 71)    RR            72            9       0 (  0/  0)%   0   9
 fp_main_task       (240/  7)    RR     288144515        24670       0 (  0/  0)%   0   8
   Summary:   total task CPU Usage 94%  (total CPUs 10)
   CPU load 9%/2%
   Individual CPU Usage 0%/1%, 73%/1%, 0%/1%, 2%/1%, 1%/1%, 1%/1%, 16%/1%, 0%/1%, 1%/1%, 1%/1%
Message Logs
*apfMsConnTask_0: Sep 02 09:10:08.672: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 78:a3:e4:a2:44:55.
*dot1xMsgTask: Sep 02 09:10:06.907: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
Previous message occurred 2 times.
*apfOrphanSocketTask: Sep 02 09:10:03.567: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 09:10:03.504: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 98:03:d8:f1:b5:98.
*apfMsConnTask_0: Sep 02 09:10:00.864: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 2c:be:08:3c:7d:4f.
*apfMsConnTask_4: Sep 02 09:10:00.428: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 00:26:82:d4:f1:29.
*apfMsConnTask_7: Sep 02 09:09:59.532: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 68:96:7b:a6:9c:f9.
*dot1xMsgTask: Sep 02 09:09:59.307: #LOG-3-Q_IND: spam_lrad.c:12825 The system has failed decoding vendor specific payload
*spamApTask3: Sep 02 09:09:57.771: #LWAPP-3-VENDOR_SPEC_ERR: spam_lrad.c:12825 The system has failed decoding vendor specific payload
*apfOrphanSocketTask: Sep 02 09:09:57.426: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*spamApTask7: Sep 02 09:09:56.969: #CAPWAP-3-SEM_RELEASE_ERR: capwap_ac_db.c:106 The system could not release exclusive access of AP entry for 64:ae:0c:87:e8:b0 in the database
*apfOrphanSocketTask: Sep 02 09:09:56.306: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_2: Sep 02 09:09:56.120: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:1f:7f:35.
*spamApTask3: Sep 02 09:09:55.216: #CAPWAP-3-SEM_RELEASE_ERR: capwap_ac_db.c:106 The system could not release exclusive access of AP entry for 64:ae:0c:90:0f:c0 in the database
*apfMsConnTask_7: Sep 02 09:09:54.355: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 6c:c2:6b:aa:7d:b6.
*apfMsConnTask_6: Sep 02 09:09:53.975: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 84:38:38:e6:59:08.
*spamApTask3: Sep 02 09:09:51.590: #LWAPP-3-VENDOR_SPEC_ERR: spam_lrad.c:12825 The system has failed decoding vendor specific payload
*spamApTask3: Sep 02 09:09:47.810: #CAPWAP-3-SEM_RELEASE_ERR: capwap_ac_db.c:106 The system could not release exclusive access of AP entry for 24:01:c7:f6:3c:d0 in the database
*spamApTask2: Sep 02 09:09:45.578: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:c4:6b:d0:  DTLS connection not found forAP  192:168:19:72 (61642), Controller: 192:168:66:66 (5246) send packet
*spamApTask2: Sep 02 09:09:45.576: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:c4:6b:d0:  DTLS connection not found forAP  192:168:19:72 (61642), Controller: 192:168:66:66 (5246) send packet
*spamApTask2: Sep 02 09:09:45.576: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 24:01:c7:c1:05:00:  DTLS connection not found forAP  192:168:19:68 (13606), Controller: 192:168:66:66 (5246) send packet
*spamApTask2: Sep 02 09:09:45.576: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:56:ee:40:  DTLS connection not found forAP  192:168:18:71 (45131), Controller: 192:168:66:66 (5246) send packet
*spamApTask2: Sep 02 09:09:45.575: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:91:36:20:  DTLS connection not found forAP  192:168:21:67 (1759), Controller: 192:168:66:66 (5246) send packet
*spamApTask2: Sep 02 09:09:45.575: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:c4:6b:d0:  DTLS connection not found forAP  192:168:19:72 (61642), Controller: 192:168:66:66 (5246) send packet
*spamApTask2: Sep 02 09:09:45.575: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 24:01:c7:c1:05:00:  DTLS connection not found forAP  192:168:19:68 (13606), Controller: 192:168:66:66 (5246) send packet
*spamApTask2: Sep 02 09:09:45.560: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:56:ee:40:  DTLS connection not found forAP  192:168:18:71 (45131), Controller: 192:168:66:66 (5246) send packet
*spamReceiveTask: Sep 02 09:09:45.540: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 0c:27:24:6d:c0:60:  DTLS connection not found forAP  192:168:18:73 (10519), Controller: 192:168:66:66 (5246) send packet
*spamReceiveTask: Sep 02 09:09:45.540: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 c0:25:5c:a3:53:20:  DTLS connection not found forAP  192:168:18:75 (41588), Controller: 192:168:66:66 (5246) send packet
*spamApTask2: Sep 02 09:09:45.532: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:91:36:20:  DTLS connection not found forAP  192:168:21:67 (1759), Controller: 192:168:66:66 (5246) send packet
*spamApTask7: Sep 02 09:09:45.458: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:56:ee:70:  DTLS connection not found forAP  192:168:18:70 (10521), Controller: 192:168:66:66 (5246) send packet
*spamApTask3: Sep 02 09:09:45.443: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 24:01:c7:f6:35:e0:  DTLS connection not found forAP  192:168:19:69 (59902), Controller: 192:168:66:66 (5246) send packet
*spamApTask3: Sep 02 09:09:45.435: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:57:fd:50:  DTLS connection not found forAP  192:168:18:72 (38979), Controller: 192:168:66:66 (5246) send packet
*spamApTask7: Sep 02 09:09:45.385: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:91:84:20:  DTLS connection not found forAP  192:168:21:66 (38965), Controller: 192:168:66:66 (5246) send packet
*spamApTask7: Sep 02 09:09:45.378: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 c0:25:5c:a3:5d:a0:  DTLS connection not found forAP  192:168:18:63 (41600), Controller: 192:168:66:66 (5246) send packet
*spamApTask7: Sep 02 09:09:45.343: #CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:798 64:ae:0c:86:6c:40:  DTLS connection not found forAP  192:168:18:66 (45349), Controller: 192:168:66:66 (5246) send packet
*apfMsConnTask_4: Sep 02 09:09:45.198: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:a6:d9:11:cd:98.
*apfMsConnTask_6: Sep 02 09:09:45.167: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 30:c7:ae:4b:fc:8a.
*apfMsConnTask_6: Sep 02 09:09:45.133: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bd:95:38.
*apfMsConnTask_6: Sep 02 09:09:45.123: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:a6:d9:11:cd:98.
*apfMsConnTask_0: Sep 02 09:09:45.121: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 78:a3:e4:a2:44:55.
*apfOrphanSocketTask: Sep 02 09:07:04.520: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 09:07:04.519: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 09:07:04.393: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 98:03:d8:f1:b5:98.
*dot1xMsgTask: Sep 02 09:07:03.447: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 09:06:57.130: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_4: Sep 02 09:06:52.379: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:a6:d9:11:cd:98.
*apfMsConnTask_0: Sep 02 09:06:49.987: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: a4:c3:61:15:80:97.
*dot1xMsgTask: Sep 02 09:06:38.811: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_1: Sep 02 09:06:32.892: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: a4:c3:61:15:80:97.
*dot1xMsgTask: Sep 02 09:06:14.411: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*dot1xMsgTask: Sep 02 09:05:50.011: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 09:05:31.876: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*dot1xMsgTask: Sep 02 09:05:26.411: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_7: Sep 02 09:05:04.245: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:21:0f:f9.
*dot1xMsgTask: Sep 02 09:05:02.011: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 09:04:47.150: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 09:04:46.793: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bc:6b:39.
*apfMsConnTask_4: Sep 02 09:04:45.782: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 84:38:38:e6:59:08.
*apfMsConnTask_0: Sep 02 09:04:43.184: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:21:0f:f9.
*dot1xMsgTask: Sep 02 09:04:36.611: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_2: Sep 02 09:04:27.554: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: a4:c3:61:15:80:97.
*dot1xMsgTask: Sep 02 09:04:13.011: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_7: Sep 02 09:04:10.769: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: a4:c3:61:15:80:97.
*apfMsConnTask_6: Sep 02 09:04:08.552: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 50:ea:d6:a3:b5:ea.
*apfMsConnTask_1: Sep 02 09:04:07.281: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:b2:80:35.
*apfMsConnTask_4: Sep 02 09:03:59.932: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_4: Sep 02 09:03:59.261: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:f3:08:fe:3c:6d.
*dot1xMsgTask: Sep 02 09:03:56.211: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_2: Sep 02 09:03:50.629: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:21:0f:f9.
*apfMsConnTask_7: Sep 02 09:03:34.919: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 70:11:24:07:14:24.
*dot1xMsgTask: Sep 02 09:03:31.811: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*dot1xMsgTask: Sep 02 09:03:07.411: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 09:02:56.855: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*dot1xMsgTask: Sep 02 09:02:38.411: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_1: Sep 02 09:02:14.559: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:20:57:e0.
*dot1xMsgTask: Sep 02 09:02:14.011: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 09:02:00.985: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_6: Sep 02 09:02:00.426: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:21:0f:f9.
*apfMsConnTask_7: Sep 02 09:01:54.823: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*dot1xMsgTask: Sep 02 09:01:46.411: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 09:01:42.787: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 09:01:42.786: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_2: Sep 02 09:01:42.361: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:21:0f:f9.
*apfMsConnTask_2: Sep 02 09:01:41.067: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:72:4f:3f:ef:f2.
*apfMsConnTask_4: Sep 02 09:01:31.210: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_7: Sep 02 09:01:23.683: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*dot1xMsgTask: Sep 02 09:01:21.811: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_6: Sep 02 09:01:12.409: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bc:6b:39.
*apfMsConnTask_4: Sep 02 09:01:12.217: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bc:6b:39.
*apfMsConnTask_0: Sep 02 09:01:09.306: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*apfMsConnTask_0: Sep 02 09:01:01.983: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bd:d2:35.
*dot1xMsgTask: Sep 02 09:00:56.211: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_1: Sep 02 09:00:54.613: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 38:0f:4a:2c:16:c0.
*apfMsConnTask_7: Sep 02 09:00:54.390: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*apfMsConnTask_4: Sep 02 09:00:46.233: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:63:df:05:81:f0.
*dot1xMsgTask: Sep 02 09:00:32.607: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 09:00:29.677: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 09:00:27.026: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:21:0f:f9.
*apfMsConnTask_2: Sep 02 09:00:14.774: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 84:b1:53:ac:82:be.
*dot1xMsgTask: Sep 02 09:00:08.207: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 09:00:00.035: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_7: Sep 02 08:59:53.963: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*dot1xMsgTask: Sep 02 08:59:42.807: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 08:59:23.390: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 08:59:23.354: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*apfMsConnTask_1: Sep 02 08:59:20.675: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a1:95:c7.
*dot1xMsgTask: Sep 02 08:59:19.407: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*dot1xMsgTask: Sep 02 08:58:59.207: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:58:58.084: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_3: Sep 02 08:58:35.811: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:78:5f:38:44:a4.
*dot1xMsgTask: Sep 02 08:58:33.807: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 08:58:24.490: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_3: Sep 02 08:58:24.437: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 38:0f:4a:2c:16:c0.
*apfMsConnTask_7: Sep 02 08:58:12.847: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 70:11:24:07:14:24.
*dot1xMsgTask: Sep 02 08:58:05.807: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:57:53.490: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:63:df:05:81:f0.
*dot1xMsgTask: Sep 02 08:57:41.403: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_7: Sep 02 08:57:41.138: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:3a:61:a2:bc:42.
*apfMsConnTask_4: Sep 02 08:57:32.873: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*dot1xMsgTask: Sep 02 08:57:16.003: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*dot1xMsgTask: Sep 02 08:56:52.203: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:56:29.727: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_1: Sep 02 08:56:27.512: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a1:95:c7.
*dot1xMsgTask: Sep 02 08:56:26.803: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_0: Sep 02 08:56:25.142: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:b2:80:35.
*apfMsConnTask_0: Sep 02 08:56:24.143: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:3a:61:57:f7:35.
*apfMsConnTask_4: Sep 02 08:56:08.258: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bc:6b:39.
*dot1xMsgTask: Sep 02 08:56:02.403: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_7: Sep 02 08:56:00.671: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:3a:61:57:f7:35.
*apfOrphanSocketTask: Sep 02 08:55:56.088: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:55:55.222: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 08:55:54.535: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 6c:c2:6b:aa:7d:b6.
*apfMsConnTask_6: Sep 02 08:55:54.210: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:f3:08:fe:3c:6d.
*dot1xMsgTask: Sep 02 08:55:38.795: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_0: Sep 02 08:55:33.264: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 6c:c2:6b:aa:7d:b6.
*apfOrphanSocketTask: Sep 02 08:55:14.897: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:55:14.896: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:55:14.796: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: d8:9e:3f:41:a3:c1.
*dot1xMsgTask: Sep 02 08:55:14.395: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:55:04.531: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_3: Sep 02 08:54:59.179: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:20:57:e0.
*apfOrphanSocketTask: Sep 02 08:54:50.882: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*dot1xMsgTask: Sep 02 08:54:48.991: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_1: Sep 02 08:54:38.947: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:3a:61:57:f7:35.
*apfOrphanSocketTask: Sep 02 08:54:38.045: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:54:38.034: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 08:54:37.979: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:b2:80:35.
*dot1xMsgTask: Sep 02 08:54:25.591: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*dot1xMsgTask: Sep 02 08:54:04.391: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:54:01.402: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*dot1xMsgTask: Sep 02 08:53:39.991: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 08:53:37.206: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 08:53:37.177: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*apfOrphanSocketTask: Sep 02 08:53:33.445: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:53:33.330: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: d8:9e:3f:41:a3:c1.
*dot1xMsgTask: Sep 02 08:53:11.991: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*emWeb: Sep 02 08:52:52.720: #EMWEB-3-LOGIN_FAILED: ews_auth.c:2104 Login failed for the user:nsnwadmin. Service-Type is not present or it doesn't allow READ/WRITE permission..
*apfMsConnTask_2: Sep 02 08:52:51.128: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:b3:e5:ae.
*dot1xMsgTask: Sep 02 08:52:47.591: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:52:40.449: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 70:11:24:07:14:24.
*apfMsConnTask_7: Sep 02 08:52:34.900: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 70:11:24:07:14:24.
*apfMsConnTask_4: Sep 02 08:52:33.484: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_7: Sep 02 08:52:32.102: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 68:96:7b:a6:9c:f9.
*dot1xMsgTask: Sep 02 08:52:22.191: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_0: Sep 02 08:52:22.182: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*apfMsConnTask_7: Sep 02 08:52:14.341: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*dot1xMsgTask: Sep 02 08:51:58.591: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_7: Sep 02 08:51:43.621: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:b3:e5:ae.
*dot1xMsgTask: Sep 02 08:51:40.991: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_1: Sep 02 08:51:15.289: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 84:b1:53:ac:82:be.
*dot1xMsgTask: Sep 02 08:51:08.791: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:51:01.579: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*dot1xMsgTask: Sep 02 08:50:44.191: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_1: Sep 02 08:50:21.354: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*dot1xMsgTask: Sep 02 08:50:19.791: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_0: Sep 02 08:50:18.940: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 84:b1:53:ac:82:be.
*apfMsConnTask_4: Sep 02 08:50:07.811: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:f6:1c:2c:e3:62.
*apfMsConnTask_4: Sep 02 08:49:59.616: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_0: Sep 02 08:49:58.718: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:3a:61:57:f7:35.
*dot1xMsgTask: Sep 02 08:49:55.391: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_7: Sep 02 08:49:36.508: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*apfMsConnTask_2: Sep 02 08:49:36.380: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 38:aa:3c:39:f7:08.
*dot1xMsgTask: Sep 02 08:49:31.791: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_0: Sep 02 08:49:27.715: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*apfOrphanSocketTask: Sep 02 08:49:15.633: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_7: Sep 02 08:49:11.046: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 68:96:7b:a6:9c:f9.
*dot1xMsgTask: Sep 02 08:49:10.791: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_7: Sep 02 08:49:10.665: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 84:b1:53:ae:9b:fc.
*dot1xMsgTask: Sep 02 08:48:46.391: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_7: Sep 02 08:48:35.235: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:b3:95:5c:26:41.
*apfMsConnTask_4: Sep 02 08:48:34.386: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*dot1xMsgTask: Sep 02 08:48:18.391: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_0: Sep 02 08:48:00.645: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 68:96:7b:a6:9c:f9.
*dot1xMsgTask: Sep 02 08:47:58.191: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:47:54.555: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a1:95:c7.
*apfMsConnTask_0: Sep 02 08:47:46.917: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 98:fe:94:2e:40:b6.
*apfMsConnTask_7: Sep 02 08:47:43.662: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:3a:61:57:f7:35.
*apfMsConnTask_4: Sep 02 08:47:41.019: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a1:95:c7.
*dot1xMsgTask: Sep 02 08:47:32.791: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:47:31.125: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_0: Sep 02 08:47:28.701: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:b2:80:35.
*apfMsConnTask_7: Sep 02 08:47:13.837: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 70:11:24:07:14:24.
*dot1xMsgTask: Sep 02 08:47:04.991: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 08:46:55.157: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_3: Sep 02 08:46:55.094: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 38:0f:4a:2c:16:c0.
*dot1xMsgTask: Sep 02 08:46:44.791: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_2: Sep 02 08:46:42.542: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:1f:ca:98.
*apfMsConnTask_1: Sep 02 08:46:23.155: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 10:9a:dd:0d:9a:0f.
*dot1xMsgTask: Sep 02 08:46:19.391: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_0: Sep 02 08:46:11.275: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 84:b1:53:ac:82:be.
*apfMsConnTask_4: Sep 02 08:46:05.944: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_1: Sep 02 08:46:03.818: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 10:9a:dd:0d:9a:0f.
*apfMsConnTask_2: Sep 02 08:46:03.344: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 84:b1:53:ac:82:be.
*apfMsConnTask_2: Sep 02 08:46:03.029: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 84:b1:53:ac:82:be.
*dot1xMsgTask: Sep 02 08:45:51.391: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_1: Sep 02 08:45:37.995: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 50:ea:d6:ed:6d:ed.
*dot1xMsgTask: Sep 02 08:45:31.191: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 08:45:09.055: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:45:08.440: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 04:46:65:c7:2f:db.
*dot1xMsgTask: Sep 02 08:45:05.791: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:44:59.038: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bd:95:38.
*apfMsConnTask_6: Sep 02 08:44:54.396: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bd:95:38.
*apfMsConnTask_0: Sep 02 08:44:45.562: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 34:e2:fd:41:b9:bc.
*apfMsConnTask_7: Sep 02 08:44:40.878: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 50:ea:d6:ed:6d:ed.
*apfMsConnTask_0: Sep 02 08:44:40.523: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 34:e2:fd:41:b9:bc.
*dot1xMsgTask: Sep 02 08:44:37.991: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_0: Sep 02 08:44:34.854: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:b2:80:35.
*apfOrphanSocketTask: Sep 02 08:44:24.778: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_1: Sep 02 08:44:24.693: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 6c:c2:6b:aa:7d:b6.
*dot1xMsgTask: Sep 02 08:44:21.191: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:44:16.913: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 00:73:e0:28:8e:4d.
*dot1xMsgTask: Sep 02 08:43:56.791: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:43:53.373: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: a4:c3:61:15:80:97.
*apfOrphanSocketTask: Sep 02 08:43:50.230: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:43:50.229: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_3: Sep 02 08:43:50.187: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:78:5f:38:44:a4.
*apfMsConnTask_6: Sep 02 08:43:42.931: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bc:6b:39.
*apfMsConnTask_4: Sep 02 08:43:39.641: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:63:df:05:81:f0.
*apfMsConnTask_4: Sep 02 08:43:39.580: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bc:6b:39.
*apfMsConnTask_4: Sep 02 08:43:39.128: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_1: Sep 02 08:43:29.634: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:3a:61:5b:64:6e.
*dot1xMsgTask: Sep 02 08:43:24.591: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_3: Sep 02 08:43:09.795: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bd:f6:19.
*dot1xMsgTask: Sep 02 08:43:04.391: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:43:00.268: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:b3:95:5c:26:41.
*apfMsConnTask_1: Sep 02 08:42:58.948: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 68:96:7b:a6:9c:f9.
*apfMsConnTask_2: Sep 02 08:42:54.539: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 68:96:7b:a6:9c:f9.
*apfOrphanSocketTask: Sep 02 08:42:47.427: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:42:45.001: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:f3:08:cb:d6:aa.
*dot1xMsgTask: Sep 02 08:42:38.991: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:42:35.977: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_7: Sep 02 08:42:12.998: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*apfMsConnTask_0: Sep 02 08:42:12.665: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*dot1xMsgTask: Sep 02 08:42:11.191: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*dot1xMsgTask: Sep 02 08:41:46.587: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:41:38.072: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:63:df:05:81:f0.
*apfMsConnTask_4: Sep 02 08:41:37.948: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bc:6b:39.
*apfOrphanSocketTask: Sep 02 08:41:33.542: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:41:33.540: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_7: Sep 02 08:41:33.507: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 70:11:24:07:14:24.
*apfOrphanSocketTask: Sep 02 08:41:28.491: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:41:27.468: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 30:c7:ae:4b:fc:8a.
*apfOrphanSocketTask: Sep 02 08:41:25.311: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*dot1xMsgTask: Sep 02 08:41:21.187: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 08:41:19.447: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:41:19.446: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:41:19.342: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: d8:9e:3f:41:a3:c1.
*apfMsConnTask_0: Sep 02 08:41:10.522: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 78:a3:e4:a2:44:55.
*apfMsConnTask_4: Sep 02 08:41:08.314: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_3: Sep 02 08:41:01.192: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:63:df:03:c8:9b.
*dot1xMsgTask: Sep 02 08:40:57.787: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_4: Sep 02 08:40:43.069: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: ac:cf:5c:bc:6b:39.
*apfOrphanSocketTask: Sep 02 08:40:41.669: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*dot1xMsgTask: Sep 02 08:40:36.587: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*dot1xMsgTask: Sep 02 08:40:12.187: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_7: Sep 02 08:40:09.634: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a4:6c:3f.
*apfOrphanSocketTask: Sep 02 08:40:05.912: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:40:05.179: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfOrphanSocketTask: Sep 02 08:40:02.407: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_7: Sep 02 08:39:59.204: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:a1:1c:98.
*apfMsConnTask_6: Sep 02 08:39:50.588: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:f3:08:fe:3c:6d.
*dot1xMsgTask: Sep 02 08:39:44.583: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 08:39:40.163: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:39:39.940: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:39:36.614: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:3a:61:5b:64:6e.
*apfOrphanSocketTask: Sep 02 08:39:32.363: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_6: Sep 02 08:39:30.065: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 30:c7:ae:4b:fc:8a.
*apfMsConnTask_1: Sep 02 08:39:24.722: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 98:03:d8:f1:b5:98.
*apfMsConnTask_6: Sep 02 08:39:20.460: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 18:20:32:67:67:30.
*dot1xMsgTask: Sep 02 08:39:19.783: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_1: Sep 02 08:39:16.975: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:20:57:e0.
*apfOrphanSocketTask: Sep 02 08:39:10.732: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:39:10.730: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_6: Sep 02 08:39:10.612: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 98:03:d8:f1:b5:98.
*apfOrphanSocketTask: Sep 02 08:39:10.487: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:39:09.768: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:39:08.781: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 08:39:08.475: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:f3:08:fe:da:02.
*apfMsConnTask_4: Sep 02 08:39:06.157: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:20:57:e0.
*apfMsConnTask_3: Sep 02 08:39:04.962: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 38:0f:4a:2c:16:c0.
*apfOrphanSocketTask: Sep 02 08:39:03.536: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_7: Sep 02 08:39:01.660: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:f3:08:fe:3c:6d.
*dot1xMsgTask: Sep 02 08:38:54.383: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfOrphanSocketTask: Sep 02 08:38:46.811: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:38:45.224: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 00:26:82:d4:f1:29.
*apfMsConnTask_0: Sep 02 08:38:43.820: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 2c:be:08:3c:7d:4f.
*apfMsConnTask_0: Sep 02 08:38:41.551: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: cc:3a:61:a2:bc:42.
*apfMsConnTask_4: Sep 02 08:38:38.817: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 88:cb:87:ee:2b:14.
*apfMsConnTask_1: Sep 02 08:38:38.156: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 54:ae:27:af:a2:fe.
*apfMsConnTask_4: Sep 02 08:38:35.599: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 6c:3e:6d:ef:f6:f0.
*dot1xMsgTask: Sep 02 08:38:26.583: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client 00:19:f5:80:45:bb may be using an incorrect PSK
*apfMsConnTask_0: Sep 02 08:38:24.085: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:1f:7e:b4.
*apfMsConnTask_4: Sep 02 08:38:23.220: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:f6:1c:2c:e3:62.
*apfMsConnTask_7: Sep 02 08:38:21.973: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: a4:c3:61:15:80:97.
*apfMsConnTask_2: Sep 02 08:38:21.403: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:1f:7f:35.
*apfOrphanSocketTask: Sep 02 08:38:21.307: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 08:38:19.903: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:20:99:43.
*apfOrphanSocketTask: Sep 02 08:38:19.010: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_4: Sep 02 08:38:18.605: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: a4:c3:61:15:80:97.
*apfMsConnTask_6: Sep 02 08:38:17.428: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:f6:1c:2c:e3:62.
*apfMsConnTask_0: Sep 02 08:38:16.893: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 38:aa:3c:39:f7:08.
*apfOrphanSocketTask: Sep 02 08:38:15.537: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:38:14.740: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_0: Sep 02 08:38:13.102: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:27:65:1f:7e:b4.
*apfMsConnTask_4: Sep 02 08:38:12.961: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: f0:f6:1c:2c:e3:62.
*apfMsConnTask_0: Sep 02 08:38:11.915: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:f3:08:96:ce:ba.
*apfMsConnTask_4: Sep 02 08:38:08.743: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:a6:d9:11:cd:98.
*apfMsConnTask_6: Sep 02 08:38:07.451: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: 40:a6:d9:11:cd:98.
*apfOrphanSocketTask: Sep 02 08:38:07.355: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*spamApTask2: Sep 02 08:38:04.963: #LWAPP-3-VENDOR_SPEC_ERR: spam_lrad.c:12825 The system has failed decoding vendor specific payload
*spamApTask4: Sep 02 08:38:03.666: #LWAPP-3-VENDOR_SPEC_ERR: spam_lrad.c:12825 The system has failed decoding vendor specific payload
*spamApTask0: Sep 02 08:38:03.251: #LWAPP-3-VENDOR_SPEC_ERR: spam_lrad.c:12825 The system has failed decoding vendor specific payload
*apfOrphanSocketTask: Sep 02 08:38:03.047: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Sep 02 08:38:03.043: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning.
*apfMsConnTask_7: Sep 02 08:38:02.924: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:378 Could not check supported rates. Missing Supported Rate. Length :0. Mobile MAC: d8:9e:3f:41:a3:c1.
*spamApTask4: Sep 02 08:38:01.965: #CAPWAP-3-SEM_RELEASE_ERR: capwap_ac_db.c:106 The system could not release exclusive access of AP entry for 64:ae:0c:90:0f:c0 in the database
*spamApTask2: Sep 02 08:38:01.730: #CAPWAP-3-SEM_RELEASE_ERR: capwap_ac_db.c:106 The system could not release exclusive access of AP entry for 24:01:c7:f6:3c:d0 in the database
*spamApTask0: Sep 02 08:38:01.558: #CAPWAP-3-SEM_RELEASE_ERR: capwap_ac_db.c:106 The system could not release exclusive access of AP entry for 64:ae:0c:87:e8:b0 in the database
*nim_t: Sep 02 08:37:41.853: #SIM-3-PORT_UP: sim.c:11269 Physical port 2 is up!.
*nim_t: Sep 02 08:37:41.853: #SIM-3-PORT_UP: sim.c:11269 Physical port 1 is up!.
*fp_main_task: Sep 02 08:37:41.852: #CNFGR-3-INV_COMP_ID: cnfgr.c:2944 Invalid Component Id : Unrecognized (94) in cfgConfiguratorInit.
*fp_main_task: Sep 02 08:37:41.852: #LOG-3-Q_IND: bonjour_api.c:1040 Service specific query: Sending serice specific query failed[...It occurred 4 times.!]
*fp_main_task: Sep 02 08:37:41.818: #BONJOUR-3-SPECIFIC_QUERY_SEND_ERR: bonjour_api.c:1040 Service specific query: Sending serice specific query failed
*ipv6SocketTask: Sep 02 08:37:32.443: #LOG-3-Q_IND: sisf_shim_utils.c:316 Internal error, NULL entry in sisf_sw_policy_get_cfg_ptr[...It occurred 3 times.!]
*fp_main_task: Sep 02 08:37:32.437: #SISF-3-INTERNAL: sisf_shim_utils.c:316 Internal error, NULL entry in sisf_sw_policy_get_cfg_ptr
*fp_main_task: Sep 02 08:37:29.081: #MM-3-MEMBER_ADD_FAILED: mm_dir.c:1197 Could not add Mobility Member. Reason: IP already assigned, Member-Count:1,MAC: 00:00:00:00:00:00, IP: 0.0.0.0
*mfpKeyRefreshTask: Sep 02 08:37:09.511: #SSHPM-3-NOT_INIT: bsnrandom.c:620 Random context not initialized
*fp_main_task: Sep 02 08:37:09.503: #CNFGR-3-INV_COMP_ID: cnfgr.c:2944 Invalid Component Id : Unrecognized (36) in cfgConfiguratorInit.
Dumping task specific information emWeb
 Crash function not supported by this task: emWeb
*********************Dump Kernel Msg*********************
*           End Cisco Crash Handler                    *
Everyone's tags (1)
Hall of Fame Super Blue
I'd contact Cisco TAC.  It
I'd contact Cisco TAC.  It looks like Cisco Bug ID CSCtx68870.
Community Member
Thank you for your input. I
Thank you for your input. I checked the Bug ID you mentioned:
CSCtx68870
Symptom : Cisco 5508 WLC stops responding every 3 hours with the following message:
unfortunately this does not look like the problem. we can't see any recurring events.
Hi Samuel,  Open the Bug ID
Hi Samuel,
Open the Bug ID and compare some of the error message you have.  They match.
Just in case, open a TAC case for a "second opinion".
951
