up to AireOS 7.6 I was able to set the font-color of the internal webauth/weblogin page using html-codes, for example like this:
Headline: Welcome to our <font color="red">guest</font>-network!
Message: You need a valid <font color="blue">user</font> to login.
Now with AireOS 8.0 this doesn't work anymore. When I try to set a headline or message with font-tags I get "Error while setting headline." (or "...message.") when I hit apply. I have to remove the font-tag to save the weblogin page.
#CLIWEB-6-CLIWEB_INVALID_HTML_TAGS_USED: [PA] cli_web_api.c:1748 The Customization message field has invalid html tags
#CLIWEB-6-CLIWEB_INVALID_HTML_TAGS_USED: [PA] cli_web_api.c:1663 The Headline field has invalid html tags
So, how can we now set different font colors/styles like in previous releases? Using external or uploading selfmade pages is not an option.
Chris
