wlc anchor aaa override with 802.1x
I have a 4402 WLC to act as an anchor controller in a DMZ enviroment.
My wireless clients associate with several WiSM's in the local network.
I would like to create a WLAN that uses 802.1x (WPA2) to authenticate the clients and then bind them to the anchor controller in the DMZ.
But I notice that the 802.1x part is being handled by the foreign controllers (WiSM's) and not by the anchor controller. So I cannot use the AAA override to assign different DMZ vlan's with my radius reply.
Is this correct ?
Gerard van Bon
Hall of Fame Super Silver
Re: wlc anchor aaa override with 802.1x
i don't think you can do that. you can put a client on a certain vlan, but since you are creating a mobility anchor to a 4402 in the DMZ, no way to push them to a WLC.
-Scott
I now also think that it is not possible.
360
