WLC AND AIRONET 1240 LWAPP CONFIG
Hi all, Can anyone tell me what I need to do to configure my 1240ag access points to work with my wlc using lwapp.
Also how reliable are the wlc's should you use a backup wlc on each site ?
1 REPLY
Hall of Fame Super Silver
Re: WLC AND AIRONET 1240 LWAPP CONFIG
Your 1240ag must be an LWAP. Look at the back of the AP and check the model. If you see AP1242 then no, but if you see LAP1242 then all you need to do is stage the LWAP to the WLC.
Backups depend on your policies and how important the wireless will be to your byusiness.
Read this doc to help you understand better. Hope this helps:
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_example09186a0080665cdf.shtml
-Scott
312
