WLC and AP
Hello guys,
I have an error when wlc trying to connect my 1042 access point
here is error
my wlc is nm-wlc intergrated module
ap and wlc have the same code version 7.0
%LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 26 09:02:27.419: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 26 09:02:27.445:  status of voice_diag_test from WLC is false
*Apr 26 09:02:38.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.1.11 peer_port: 5246
*Apr 26 09:02:38.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Apr 26 09:02:39.116: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.1.11 peer_port: 5246
*Apr 26 09:02:39.117: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.1.11
*Apr 26 09:02:39.118: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 26 09:02:39.291: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Apr 26 09:02:39.292: %DTLS-5-ALERT: Received WARNING : Close notify alert from 172.16.1.11
*Apr 26 09:02:39.293: %DTLS-5-PEER_DISCONNECT: Peer 172.16.1.11 has closed connection.
*Apr 26 09:02:39.293: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.16.1.11:5246
*Apr 26 09:02:39.346: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Apr 26 09:02:39.447:  status of voice_diag_test from WLC is false
*Apr 26 09:02:49.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.1.11 peer_port: 5246
*Apr 26 09:02:49.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Apr 26 09:02:50.114: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.1.11 peer_port: 5246
*Apr 26 09:02:50.115: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.1.11
*Apr 26 09:02:50.115: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 26 09:02:50.287: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Apr 26 09:02:50.289: %DTLS-5-ALERT: Received WARNING : Close notify alert from 172.16.1.11
*Apr 26 09:02:50.289: %DTLS-5-PEER_DISCONNECT: Peer 172.16.1.11 has closed connection.
*Apr 26 09:02:50.289: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.16.1.11:5246
*Apr 26 09:02:50.344: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Apr 26 09:02:50.370: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Apr 26 09:02:50.370: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Apr 26 09:02:51.325: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 26 09:02:51.352:  status of voice_diag_test from WLC is false
*Apr 26 09:02:51.352: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Apr 26 09:02:51.360: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 26 09:02:51.372: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Apr 26 09:02:51.372: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Apr 26 09:02:51.386: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Apr 26 09:02:52.386: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Apr 26 09:03:02.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.1.11 peer_port: 5246
*Apr 26 09:03:02.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Apr 26 09:03:03.109: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.1.11 peer_port: 5246
*Apr 26 09:03:03.110: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.1.11
*Apr 26 09:03:03.110: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 26 09:03:03.285: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Apr 26 09:03:03.287: %DTLS-5-ALERT: Received WARNING : Close notify alert from 172.16.1.11
Building configuration...
CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination
On the WLC GUI, go to Wireless, Country and set the correct country code there.
Please don't forget to rate our useful posts.
13 Replies 13
Stephen Rodriguez
what version of 7.0 are you running on the WLC?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
7,0.240.0 version, when i connected AP to switch, its automaticaly joined to it, received Image from wlc, but after that an error
%DTLS-5-ALERT: Received WARNING : Close notify alert from 172.16.1.11 appears, and it begin to discover process again
can you grab the following debugs from the WLC:
debug mac-address < ap mac address>
debug capwap events enable
debug capwap erros enable
Steve
HTH,
Steve
Can you please post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  WAP:  sh inventory
Guys here is all diagnostics
WAP
#show inventory
NAME: "AP1040", DESCR: "Cisco Aironet 1040 Series (IEEE 802.11n) Access Point"
PID: AIR-AP1042N-E-K9  , VID: V02, SN: FCZ1537W1MW
WLC
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.230.0
RTOS Version..................................... 7.0.230.0
Bootloader Version............................... 7.0.230.0
Emergency Image Version.......................... N/A
Build Type....................................... DATA + WPS
System Name...................................... Cisco_cc:c4:20
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.818
IP Address....................................... 172.16.1.10
System Up Time................................... 0 days 19 hrs 17 mins 2 secs
System Timezone Location.........................
Configured Country............................... US  - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
--More-- or (q)uit
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:1E:BE:CC:C4:20
Maximum number of APs supported.................. 8
(Cisco Controller) >*spamReceiveTask: Apr 26 16:30:25.589: 68:bc:0c:0b:ca:a0 DTLS connection not found, creating new connection for 172:16:100:132 (38305) 172:16:1:11 (5246)
*spamReceiveTask: Apr 26 16:30:26.715: 68:bc:0c:0b:ca:a0 DTLS Session established server (172.16.1.11:5246), client (172.16.100.132:38305)
*spamReceiveTask: Apr 26 16:30:26.715: 68:bc:0c:0b:ca:a0 Starting wait join timer for AP: 172.16.100.132:38305
d*spamReceiveTask: Apr 26 16:30:26.718: 68:bc:0c:0b:ca:a0 Join Request from 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:30:26.718: 68:bc:0c:0b:ca:a0 Deleting AP entry 172.16.100.132:38305 from temporary database.
*spamReceiveTask: Apr 26 16:30:26.720: 68:bc:0c:0b:ca:a0 Join Version: = 117499392
*spamReceiveTask: Apr 26 16:30:26.720: 68:bc:0c:0b:ca:a0 Join resp: CAPWAP Maximum Msg element len = 91
*spamReceiveTask: Apr 26 16:30:26.720: 68:bc:0c:0b:ca:a0 Join Response sent to 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:30:26.720: 68:bc:0c:0b:ca:a0 CAPWAP State: Join
*spamReceiveTask: Apr 26 16:30:26.720: 68:bc:0c:0b:ca:a0 capwap_ac_platform.c:1217 - Operation State 0 ===> 4
*apfReceiveTask: Apr 26 16:30:26.721: 68:bc:0c:0b:ca:a0 Register LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 0
*apfReceiveTask: Apr 26 16:30:26.721: WARP IEs: (12)
*apfReceiveTask: Apr 26 16:30:26.721:      [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
*apfReceiveTask: Apr 26 16:30:26.721: 68:bc:0c:0b:ca:a0 Register LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 1
*spamReceiveTask: Apr 26 16:30:26.840: 68:bc:0c:0b:ca:a0 Configuration Status from 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:30:26.840: 68:bc:0c:0b:ca:a0 CAPWAP State: Configure
*spamReceiveTask: Apr 26 16:30:26.840: Invalid channel 1 spacified for the AP AP7081.05c9.5a08, slotId = 0
*spamReceiveTask: Apr 26 16:30:26.840: Invalid channel 64 spacified for the AP AP7081.05c9.5a08, slotId = 1
*spamReceiveTask: Apr 26 16:30:26.840: 68:bc:0c:0b:ca:a0 Updating IP info for AP 68:bc:0c:0b:ca:a0 -- static 1, 10.0.0.4/255.255.255.0, gtw 172.30.30.1
*spamReceiveTask: Apr 26 16:30:26.841: 68:bc:0c:0b:ca:a0 Updated IP Domain info for AP 68:bc:0c:0b:ca:a0 -- set 0, Domain
*spamReceiveTask: Apr 26 16:30:26.841: 68:bc:0c:0b:ca:a0 Updating IP NamServer info for AP 68:bc:0c:0b:ca:a0 -- set 0, nameserver 0.0.0.0
*spamReceiveTask: Apr 26 16:30:26.841: 68:bc:0c:0b:ca:a0 Setting MTU to 1485
*spamReceiveTask: Apr 26 16:30:26.841: 68:bc:0c:0b:ca:a0 Finding DTLS connection to delete for AP (172:16:100:132/38305)
*spamReceiveTask: Apr 26 16:30:26.841: 68:bc:0c:0b:ca:a0 Disconnecting DTLS Capwap-Ctrl session 0xa0726f4 for AP (172:16:100:132/38305)
*spamReceiveTask: Apr 26 16:30:26.841: 68:bc:0c:0b:ca:a0 CAPWAP State: Dtls tear down
*spamReceiveTask: Apr 26 16:30:26.842: 68:bc:0c:0b:ca:a0 DTLS connection closed event receivedserver (172:16:1:11/5246) client (172:16:100:132/38305)
*spamReceiveTask: Apr 26 16:30:26.842: 68:bc:0c:0b:ca:a0 Entry exists for AP (172:16:100:132/38305)
*spamReceiveTask: Apr 26 16:30:26.842: 68:bc:0c:0b:ca:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 0
*spamReceiveTask: Apr 26 16:30:26.842: 68:bc:0c:0b:ca:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 1
*spamReceiveTask: Apr 26 16:30:26.842: 68:bc:0c:0b:ca:a0 No AP entry exist in temporary database for 172.16.100.132:38305
*apfReceiveTask: Apr 26 16:30:26.842: 68:bc:0c:0b:ca:a0 Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 0
*apfReceiveTask: Apr 26 16:30:26.842: 68:bc:0c:0b:ca:a0 Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 1
*spamReceiveTask: Apr 26 16:30:27.002: 68:bc:0c:0b:ca:a0 Discovery Request from 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:30:27.002: 68:bc:0c:0b:ca:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 8, joined Aps =0
*spamReceiveTask: Apr 26 16:30:27.002: 68:bc:0c:0b:ca:a0 Discovery Response sent to 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:30:37.243: 68:bc:0c:0b:ca:a0 DTLS connection not found, creating new connection for 172:16:100:132 (38306) 172:16:1:11 (5246)
*spamReceiveTask: Apr 26 16:30:38.365: 68:bc:0c:0b:ca:a0 DTLS Session established server (172.16.1.11:5246), client (172.16.100.132:38306)
*spamReceiveTask: Apr 26 16:30:38.365: 68:bc:0c:0b:ca:a0 Starting wait join timer for AP: 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:30:38.368: 68:bc:0c:0b:ca:a0 Join Request from 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:30:38.369: 68:bc:0c:0b:ca:a0 Deleting AP entry 172.16.100.132:38306 from temporary database.
*spamReceiveTask: Apr 26 16:30:38.370: 68:bc:0c:0b:ca:a0 Join Version: = 117499392
*spamReceiveTask: Apr 26 16:30:38.370: 68:bc:0c:0b:ca:a0 Join resp: CAPWAP Maximum Msg element len = 91
*spamReceiveTask: Apr 26 16:30:38.370: 68:bc:0c:0b:ca:a0 Join Response sent to 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:30:38.370: 68:bc:0c:0b:ca:a0 CAPWAP State: Join
*spamReceiveTask: Apr 26 16:30:38.370: 68:bc:0c:0b:ca:a0 capwap_ac_platform.c:1217 - Operation State 0 ===> 4
*apfReceiveTask: Apr 26 16:30:38.371: 68:bc:0c:0b:ca:a0 Register LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 0
*apfReceiveTask: Apr 26 16:30:38.371: WARP IEs: (12)
*apfReceiveTask: Apr 26 16:30:38.371:      [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
*apfReceiveTask: Apr 26 16:30:38.371: 68:bc:0c:0b:ca:a0 Register LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 1
*spamReceiveTask: Apr 26 16:30:38.490: 68:bc:0c:0b:ca:a0 Configuration Status from 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:30:38.490: 68:bc:0c:0b:ca:a0 CAPWAP State: Configure
*spamReceiveTask: Apr 26 16:30:38.490: Invalid channel 1 spacified for the AP AP7081.05c9.5a08, slotId = 0
*spamReceiveTask: Apr 26 16:30:38.490: Invalid channel 157 spacified for the AP AP7081.05c9.5a08, slotId = 1
*spamReceiveTask: Apr 26 16:30:38.490: 68:bc:0c:0b:ca:a0 Updating IP info for AP 68:bc:0c:0b:ca:a0 -- static 1, 10.0.0.4/255.255.255.0, gtw 172.30.30.1
*spamReceiveTask: Apr 26 16:30:38.490: 68:bc:0c:0b:ca:a0 Updated IP Domain info for AP 68:bc:0c:0b:ca:a0 -- set 0, Domain
*spamReceiveTask: Apr 26 16:30:38.490: 68:bc:0c:0b:ca:a0 Updating IP NamServer info for AP 68:bc:0c:0b:ca:a0 -- set 0, nameserver 0.0.0.0
*spamReceiveTask: Apr 26 16:30:38.490: 68:bc:0c:0b:ca:a0 Setting MTU to 1485
*spamReceiveTask: Apr 26 16:30:38.491: 68:bc:0c:0b:ca:a0 Finding DTLS connection to delete for AP (172:16:100:132/38306)
*spamReceiveTask: Apr 26 16:30:38.491: 68:bc:0c:0b:ca:a0 Disconnecting DTLS Capwap-Ctrl session 0xa0727d8 for AP (172:16:100:132/38306)
*spamReceiveTask: Apr 26 16:30:38.491: 68:bc:0c:0b:ca:a0 CAPWAP State: Dtls tear down
*spamReceiveTask: Apr 26 16:30:38.491: 68:bc:0c:0b:ca:a0 DTLS connection closed event receivedserver (172:16:1:11/5246) client (172:16:100:132/38306)
*spamReceiveTask: Apr 26 16:30:38.491: 68:bc:0c:0b:ca:a0 Entry exists for AP (172:16:100:132/38306)
*spamReceiveTask: Apr 26 16:30:38.492: 68:bc:0c:0b:ca:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 0
*spamReceiveTask: Apr 26 16:30:38.492: 68:bc:0c:0b:ca:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 1
*spamReceiveTask: Apr 26 16:30:38.492: 68:bc:0c:0b:ca:a0 No AP entry exist in temporary database for 172.16.100.132:38306
*apfReceiveTask: Apr 26 16:30:38.492: 68:bc:0c:0b:ca:a0 Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 0
*apfReceiveTask: Apr 26 16:30:38.492: 68:bc:0c:0b:ca:a0 Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 1
*spamReceiveTask: Apr 26 16:30:39.795: 68:bc:0c:0b:ca:a0 Discovery Request from 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:30:39.795: 68:bc:0c:0b:ca:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 8, joined Aps =0
*spamReceiveTask: Apr 26 16:30:39.795: 68:bc:0c:0b:ca:a0 Discovery Response sent to 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:30:50.035: 68:bc:0c:0b:ca:a0 DTLS connection not found, creating new connection for 172:16:100:132 (38305) 172:16:1:11 (5246)
*spamReceiveTask: Apr 26 16:30:51.158: 68:bc:0c:0b:ca:a0 DTLS Session established server (172.16.1.11:5246), client (172.16.100.132:38305)
*spamReceiveTask: Apr 26 16:30:51.158: 68:bc:0c:0b:ca:a0 Starting wait join timer for AP: 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:30:51.162: 68:bc:0c:0b:ca:a0 Join Request from 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:30:51.162: 68:bc:0c:0b:ca:a0 Deleting AP entry 172.16.100.132:38305 from temporary database.
*spamReceiveTask: Apr 26 16:30:51.163: 68:bc:0c:0b:ca:a0 Join Version: = 117499392
*spamReceiveTask: Apr 26 16:30:51.163: 68:bc:0c:0b:ca:a0 Join resp: CAPWAP Maximum Msg element len = 91
*spamReceiveTask: Apr 26 16:30:51.164: 68:bc:0c:0b:ca:a0 Join Response sent to 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:30:51.164: 68:bc:0c:0b:ca:a0 CAPWAP State: Join
*spamReceiveTask: Apr 26 16:30:51.164: 68:bc:0c:0b:ca:a0 capwap_ac_platform.c:1217 - Operation State 0 ===> 4
*apfReceiveTask: Apr 26 16:30:51.164: 68:bc:0c:0b:ca:a0 Register LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 0
*apfReceiveTask: Apr 26 16:30:51.164: WARP IEs: (12)
*apfReceiveTask: Apr 26 16:30:51.164:      [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
*apfReceiveTask: Apr 26 16:30:51.164: 68:bc:0c:0b:ca:a0 Register LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 1
*spamReceiveTask: Apr 26 16:30:51.284: 68:bc:0c:0b:ca:a0 Configuration Status from 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:30:51.284: 68:bc:0c:0b:ca:a0 CAPWAP State: Configure
*spamReceiveTask: Apr 26 16:30:51.284: Invalid channel 1 spacified for the AP AP7081.05c9.5a08, slotId = 0
*spamReceiveTask: Apr 26 16:30:51.284: Invalid channel 36 spacified for the AP AP7081.05c9.5a08, slotId = 1
*spamReceiveTask: Apr 26 16:30:51.284: 68:bc:0c:0b:ca:a0 Updating IP info for AP 68:bc:0c:0b:ca:a0 -- static 1, 10.0.0.4/255.255.255.0, gtw 172.30.30.1
*spamReceiveTask: Apr 26 16:30:51.285: 68:bc:0c:0b:ca:a0 Updated IP Domain info for AP 68:bc:0c:0b:ca:a0 -- set 0, Domain
*spamReceiveTask: Apr 26 16:30:51.285: 68:bc:0c:0b:ca:a0 Updating IP NamServer info for AP 68:bc:0c:0b:ca:a0 -- set 0, nameserver 0.0.0.0
*spamReceiveTask: Apr 26 16:30:51.285: 68:bc:0c:0b:ca:a0 Setting MTU to 1485
*spamReceiveTask: Apr 26 16:30:51.285: 68:bc:0c:0b:ca:a0 Finding DTLS connection to delete for AP (172:16:100:132/38305)
*spamReceiveTask: Apr 26 16:30:51.285: 68:bc:0c:0b:ca:a0 Disconnecting DTLS Capwap-Ctrl session 0xa0728bc for AP (172:16:100:132/38305)
*spamReceiveTask: Apr 26 16:30:51.285: 68:bc:0c:0b:ca:a0 CAPWAP State: Dtls tear down
*spamReceiveTask: Apr 26 16:30:51.286: 68:bc:0c:0b:ca:a0 DTLS connection closed event receivedserver (172:16:1:11/5246) client (172:16:100:132/38305)
*spamReceiveTask: Apr 26 16:30:51.286: 68:bc:0c:0b:ca:a0 Entry exists for AP (172:16:100:132/38305)
*spamReceiveTask: Apr 26 16:30:51.286: 68:bc:0c:0b:ca:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 0
*spamReceiveTask: Apr 26 16:30:51.286: 68:bc:0c:0b:ca:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 1
*spamReceiveTask: Apr 26 16:30:51.286: 68:bc:0c:0b:ca:a0 No AP entry exist in temporary database for 172.16.100.132:38305
*apfReceiveTask: Apr 26 16:30:51.286: 68:bc:0c:0b:ca:a0 Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 0
*apfReceiveTask: Apr 26 16:30:51.286: 68:bc:0c:0b:ca:a0 Deregister LWAPP event for AP 68:bc:0c:0b:ca:a0 slot 1
*spamReceiveTask: Apr 26 16:30:51.448: 68:bc:0c:0b:ca:a0 Discovery Request from 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:30:51.448: 68:bc:0c:0b:ca:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 8, joined Aps =0
*spamReceiveTask: Apr 26 16:30:51.448: 68:bc:0c:0b:ca:a0 Discovery Response sent to 172.16.100.132:38306
(Cisco Controller) >debug capwap errors enable
(Cisco Controller) >*spamReceiveTask: Apr 26 16:32:02.548: 68:bc:0c:0b:ca:a0 AP 68:bc:0c:0b:ca:a0: Invalid country code ().
*spamReceiveTask: Apr 26 16:32:02.548: 68:bc:0c:0b:ca:a0 PHY_TX_POWER_PAYLOAD: Invalid Tx Power Level 0
*spamReceiveTask: Apr 26 16:32:02.548: 68:bc:0c:0b:ca:a0 Configured Static IP Address not valid for AP 68:bc:0c:0b:ca:a0
*spamReceiveTask: Apr 26 16:32:02.548: 68:bc:0c:0b:ca:a0 Regulatory Domain Mismatch: AP 68:bc:0c:0b:ca:a0 not allowed to join. Regulatory Domain check failed.
Allow
*spamReceiveTask: Apr 26 16:32:02.549: 68:bc:0c:0b:ca:a0 Failed post decode processing of config status from 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:32:02.549: 68:bc:0c:0b:ca:a0 State machine handler: Failed to process  msg type = 5 state = 5 from 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:32:02.549: 68:bc:0c:0b:ca:a0 Failed to parse CAPWAP packet from 172.16.100.132:38305
*spamReceiveTask: Apr 26 16:32:02.550: 68:bc:0c:0b:ca:a0 Discarding non-ClientHello Handshake OR DTLS encrypted packet from  172.16.100.132:38305)since DTLS session is not established
*spamReceiveTask: Apr 26 16:32:14.196: 68:bc:0c:0b:ca:a0 AP 68:bc:0c:0b:ca:a0: Invalid country code ().
*spamReceiveTask: Apr 26 16:32:14.196: 68:bc:0c:0b:ca:a0 PHY_TX_POWER_PAYLOAD: Invalid Tx Power Level 0
*spamReceiveTask: Apr 26 16:32:14.196: 68:bc:0c:0b:ca:a0 Configured Static IP Address not valid for AP 68:bc:0c:0b:ca:a0
*spamReceiveTask: Apr 26 16:32:14.196: 68:bc:0c:0b:ca:a0 Regulatory Domain Mismatch: AP 68:bc:0c:0b:ca:a0 not allowed to join. Regulatory Domain check failed.
Allow
*spamReceiveTask: Apr 26 16:32:14.197: 68:bc:0c:0b:ca:a0 Failed post decode processing of config status from 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:32:14.197: 68:bc:0c:0b:ca:a0 State machine handler: Failed to process  msg type = 5 state = 5 from 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:32:14.197: 68:bc:0c:0b:ca:a0 Failed to parse CAPWAP packet from 172.16.100.132:38306
*spamReceiveTask: Apr 26 16:32:14.198: 68:bc:0c:0b:ca:a0 Discarding non-ClientHello Handshake OR DTLS encrypted packet from  172.16.100.132:38306)since DTLS session is not established
debug capwap errors disable
Your WLC is configured with the wrong regulatory domain.
The WLC is configured for US (aka "A") and the WAP is for European standard (aka "E").
How can i change regulatory domain on wlc or ap
Thank you guys,
i entered wlc  and wrote
country code SE(sweden)
then i reload wlc, and ap succesfully joined to it
Perfect.  Glad to see it works.
Had exactly the same issue, this worked perfectly.
@leolaohoo thanks
Thanks Leo for providing this useful information 5+
Thanks & Regards
