WLC and IPv6
Hi All,
has anybody experiences with WLC and IPv6? I have activated the Check Box for IPv6 Support, but it does not work. Regards, Michael
Re: WLC and IPv6
Hi ,
Have you configued uplink router/sw to support ipv6 ; the sample config would look like this
ipv6 unicast-routing
interface FastEthernet0/0.6
encapsulation dot1Q 56
ip address 10.50.56.1 255.255.255.0
ip access-group GNS2 in
ip access-group GNS2 out
ip helper-address 10.50.1.21
ip pim sparse-dense-mode
ip multicast ttl-threshold 1
no snmp trap link-status
ipv6 address 2006::/64 eui-64
ipv6 address autoconfig
ipv6 enable
let me if this works for you or not
regards
Seema
Re: WLC and IPv6
Hi Seema, thanks for your response. Unfortunately the Customer uses Alcatel Switchrouters for his Infrastructure, but IPv6 runs excellent. Only the Bridging above the WLC does not work. Any more hints? Best Regards, Michael
316
