WLC - Cluster ..?
Fernando_Meza
Level 7
Level 7
Hi netpros,
Just a quick question regarding the WLC. I am rolling out 2 per site for redundancy and load sharing. Regarding the configuration of the controllers are they completely independent or can it be replicated .. things like WLANs, local users, local MAC filtering .. etc. NOTE: I don't have WCS at this stage.
As always your input is much appreciated.
Rob Huffman
Hi Fernando,
Sadly, there is no replication between WLC's as there might be in CUCM etc. The config can be duplicated (manually) but not replicated across boxes.
Hope this helps!
Rob
Rob Huffman
Hi Fernando,
Hope this helps!
Rob
Thanks Rob .. I thought so :-(
Fernando,
When you migrate to WCS, you will have the ability to manage your controllers with the use of templates. Which is nice ...
