08-14-2009 09:10 AM - edited 07-03-2021 05:56 PM
Hi guys.. just one quick question:
What exactly is saved in the configuration file backed up from a WLC 4404?
If we have a local database configured with 100+ of users (MACs addresses), and we use the "upload configuration" feature, is the database going to be backed up too?
PS: We are using 4.2 software.
Thanks in advance!
Solved! Go to Solution.
08-14-2009 02:09 PM
the backup config of the controller, will have this part included.
08-14-2009 09:31 AM
The file is XML - open it up and check out what's in there.
08-14-2009 01:11 PM
the database is not backed up, only the configuration. It doesnt make sense to back up the database of the WLC as that is live production data.
The configuration file, xml format, will not have all the commands that you can see in the WLC.
Check this post out as well:
08-14-2009 02:00 PM
By MAC address I mean the local database for user authentication (we are using MAC address authentication). Not the clients connected at some point.
So if this database is not in the backup, and we need to reconfigure the WLC, we will have to enter all this MAC addresses again.
08-14-2009 02:09 PM
08-14-2009 02:21 PM
thanks!!
08-15-2009 06:52 AM
I would still recommend that you examine the XML file and see what's in there.
09-11-2013 09:48 PM
Just want to share a good doc relaterd to How to Save, backup or upload Configuration Script on WLC:
