WLC Config Review
Hi all,
I have 2 WLan Controlers, managing about 120 LW APs.
Could u please, take a look, in one of the Controlers Config, to see, if there are any best practic that i could apply.
Security issues, etc...
Note: I've posted this conversation previously in a wrong section. Sy about that.
Best Regards
Bruno Petrónio
1 REPLY
Re: WLC Config Review
Without knowing your requirement , it is dificult to conclude anything,
Just had a small look at ur config , and found :
1. DTPC is disabled which should be enabled
2. Client exclusion is disabled
3. 11n support is disabled
4. security is not WPA on WLAN
5. No of probes fwd to ctlr is limited
etc etc
122
