01-24-2012 02:49 PM - edited 07-03-2021 09:26 PM
Hi, I have a problem with a 4402 Wireless LAN Controller running 7.0.116.0 versión. The equipment is working fine, but after a hard reset i lost date and time
configuration.No other configuration is affected, only date and time. What can be the cause of this?
01-24-2012 02:52 PM
It should of been fine as long as you saved the configuration. I haven't seen the time and day change when I hard boot any wlc.
Scott Fella
Sent from my iPhone
01-24-2012 02:58 PM
Hi Scott,
The configuration was saved before the hard reset. I can also say that if i do a software reset on this controller, the configuration is retained, but every time i turn the switch off, this particular thing is lost.
01-24-2012 03:11 PM
What model wlc? I have a 2006, 2106, 2504 & a 5508 with no issues.
Scott Fella
Sent from my iPhone
12-28-2016 06:50 AM
Hi All,
I have a controller of 2504 with the system time badly configured......It's showing "Sat Jan 1 06:42:29 2000". How can I correct this date & time.
Thanks.
12-28-2016 07:12 AM
Hi All,
Have already reset the time.
Thanks.
01-24-2012 03:04 PM
Hummm is there a battery on the board to keep the time ?
01-24-2012 03:19 PM
WLC4402 running version 7.0.116.0. I looked for a battery in a stock equipment and found nothing
01-24-2012 05:16 PM
When you mean "lost" do you mean you don't have an NTP configured?
01-24-2012 08:40 PM
That's correct, there are no NTP configuration
01-25-2012 12:45 AM
If you don't have a valid NTP source, when the WLC reboots it reverts to default time. I believe the WLC does not "remember" the time and date, hench the Cisco recommendation to configure an NTP source. Failure to do so will cause the WLC to loose track and prevent the WAPs from joining the WLC in the future.
01-25-2012 10:09 AM
Well... I took off my NTP configuration on my 5508 and just shut the power off and left it off for a day. I just booted it back on and the time is correct. Who knows
01-25-2012 11:16 AM
So, do you think this is a hardware problem? Because as you say, i have rebooted several controllers in the past and i have never seen this... I will test with an NTP configured, but if this is a hardware problem i have to take action
Thank you all
01-25-2012 11:19 AM
I don't know if its a hardware problem... I don't have a 4400 to test with. Like Leo mentioned, if you do setup an NTP, the time will always sync to that no matter what.
04-25-2013 01:45 AM
This looks like old post but we have a client right now (April 25, 2013) with similar problem but in WLC 5508. The date and time set back to January 1, 2000 whenever we turn the power switch off at the back of WLC. We have plenty of 5508 deployment but never encountered this problem until now.
