Community Member
WLC dhcp
Hi:
I have a WLC 4000 series and 10 APs 1200, the WLC is running in Layer3 mode, a get that all APs registered in the WLC, i running a DHCP server on the WLC all APs are getting addresses from the WLC but i don't get any address in the clients from any of those APs.
Community Member
Re: WLC dhcp
Hey,
can it be that you access point and the clients are in different vlan's with different ip addresses. So you need a second DHCP scope for the clients.
Hall of Fame Super Silver
Re: WLC dhcp
Alos make sure you have configured the dynamic interface for the subnet the clients will be on and that you have mapped that under the wlan ssid. On the dynamic interface, make sure you specify the management IP Address under primary DHCP and that on the wlan ssid, the dhcp override check box is not checked.
-Scott
419
