Community Member
WLC does not boot after Upgrade to 7.4.110.0
I upgrade the WLC5508 to software 7.4.110.0.
After the reboot the WLC doesn't boot anymore....
The following message appears (connected serial with the console port)....
Verifying boot loader integrity... OK.
OCTEON CN5645-NSP pass 2.1, Core clock: 600 MHz, DDR clock: 330 MHz (660 Mhz data rate)
FPGA Revision 1.7
Env FW Revision 1.8
USB Console Revision 2.2
DRAM:  1024 MB
Flash: 32 MB
Clearing DRAM........ done
Network: octeth0', octeth1
  ' - Active interface
  E - Environment MAC address override
CF Bus 0 (IDE): OK
IDE device 0:
 - Model: STEC M2T CF 1.0.0 Firm: K1367MIX Ser#: STIM2Q4213225090200
 - Type: Hard Disk
 - Capacity: 977.4 MB = 0.9 GB (2001888 x 512)
Press <ESC> now to access the Boot Menu...
Loading primary image (7.4.110.0)
100%
34513219 bytes read
Launching...
init started: BusyBox v1.6.0 (2010-05-13 17:50:10 EDT) multi-call binary
starting pid 821, tty '': '/etc/init.d/rcS'
Set PLX switch MPS settings .............!!!!!!!
Detecting Hardware ...
set smp_affinity for irq 48
003f
DP from CGE5.0 ...
...and here the boot process stops!!
Thanks a lot for your advices
Carsten
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Contact TAC to get the
Contact TAC to get the appliace RMA-ed.
1 REPLY
76
