Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
WLC for both internal and flexconnect APs
Hi all.
We have three 5508 serving our internal AP's. Now we have started testing flexconnect for our remote offices, but there is a problem.
In our firewall we have set up a NAT-address for one of the 5508, and in the configuration for the management-interface on that 5508 we have enabled NAT address and entered the external IP, the flexconnect AP (1131) now joins ok. But now the internal AP's dont rejoin the controller if they lose connection, probably because the controller send the extrnal IP in the join reply.
Is there a workaround for this? Since we have enabled LAG, it seems that we can have only one AP manager interface on the controller.
We dont want to have one 5508 dedicated for just flexconnect.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: WLC for both internal and flexconnect APs
This is the command you need to enter in the CLI:
config network ap-discovery nat-ip-only disable
-Scott
-Scott
Yes that did it! Thanks!
192
