WLC > WLAN > SSID > L3 Security > Passthru
Jason Aarons
Level 6
Level 6
With passthru security the end user get a pop-up warning about accepting the self signed certifcate from the virtual ip 1.1.1.3.
Is there a way to replace the certificate with a trusted public certificate?
gamccall
Level 4
Level 4
There's a page on the Cisco Support Wiki which addresses this. http://tinyurl.com/5bho6s
c.fuller
You can disable https: on the controller. This will eliminate that windows pop-up warning. You need to reboot the controller for change to take effect.
Or you can install an actual SSL certificate on the controller.
For ease of administration I went with option 1 so I did not have to worry about renewing the certificate every year.
