11-04-2013 07:16 PM - edited 07-04-2021 01:12 AM
We have 2 wlc 5508 with software 7.5.102.0, both wlc have 25 AP license.
We try to setup HA SSO but 1 wlc in maintenance mode: Maintenance cause= Incompatible Software license
Could you help me ?
thanks.
============== Primary controller===========================
(Cisco Controller) >show redundancy summary
Redundancy Mode = SSO ENABLED
Local State = ACTIVE
Peer State = UNKNOWN - Communication Down
Unit = Primary
Unit ID = BC:16:65:F9:19:60
Redundancy State = Non Redundant
Mobility MAC = BC:16:65:F9:19:60
Redundancy Management IP Address................. 192.168.11.11
Peer Redundancy Management IP Address............ 192.168.11.12
Redundancy Port IP Address....................... 169.254.11.11
Peer Redundancy Port IP Address.................. 169.254.11.12
(Cisco Controller) >show interface summary
Number of Interfaces.......................... 5
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
management LAG 30 192.168.11.9 Static Yes No
redundancy-management LAG 30 192.168.11.11 Static No No
redundancy-port - untagged 169.254.11.11 Static No No
service-port N/A N/A 0.0.0.0 DHCP No No
virtual N/A N/A 1.1.1.1 Static No No
============== Secondary controller===========================
Local State = MAINTENANCE
Unit = Primary
Unit ID = F8:72:EA:EE:86:60
Mobility MAC = F8:72:EA:EE:86:60
Maintenance Mode = Enabled
Redundancy Management IP Address................. 192.168.11.12
Peer Redundancy Management IP Address............ 192.168.11.11
Redundancy Port IP Address....................... 169.254.11.12
Peer Redundancy Port IP Address.................. 169.254.11.11
management LAG 30 192.168.11.10 Static Yes No
redundancy-management LAG 30 192.168.11.12 Static No No
redundancy-port - untagged 169.254.11.12 Static No No
Solved! Go to Solution.
11-04-2013 08:45 PM
In order to use a WLC that has a license as an HA WLC, you need a minimum of a 50 AP license.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml
If you want to convert any existing WLC as a Standby WLC, do so using the config redundancy unit secondary command in the CLI. This CLI command will only work if the WLC which is intended to work as Standby has some number of permanent license count. This condition is only valid for the 5500 WLC, where a minimum of 50 AP Permanent licenses are needed to be converted to Standby. There is no restriction for other WLCs such as the WiSM2, 7500, and 8500.
11-04-2013 08:45 PM
