wlc ha maintenance mode
We have 2 wlc 5508 with software  7.5.102.0, both wlc have 25 AP license.
We try to setup HA SSO but 1 wlc in  maintenance mode: Maintenance cause= Incompatible Software license
Could you help me ?
thanks.
============== Primary controller===========================
(Cisco Controller) >show redundancy summary
            Redundancy Mode = SSO ENABLED
                Local State = ACTIVE
                 Peer State = UNKNOWN - Communication Down
                       Unit = Primary
                    Unit ID = BC:16:65:F9:19:60
           Redundancy State = Non Redundant
               Mobility MAC = BC:16:65:F9:19:60
Redundancy Management IP Address................. 192.168.11.11
Peer Redundancy Management IP Address............ 192.168.11.12
Redundancy Port IP Address....................... 169.254.11.11
Peer Redundancy Port IP Address.................. 169.254.11.12
(Cisco Controller) >show interface summary
Number of Interfaces.......................... 5
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       LAG  30       192.168.11.9    Static  Yes    No
redundancy-management            LAG  30       192.168.11.11   Static  No     No
redundancy-port                  -    untagged 169.254.11.11   Static  No     No
service-port                     N/A  N/A      0.0.0.0         DHCP    No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
============== Secondary controller===========================
                Local State = MAINTENANCE
                       Unit = Primary
                    Unit ID = F8:72:EA:EE:86:60
               Mobility MAC = F8:72:EA:EE:86:60
Maintenance Mode = Enabled
Redundancy Management IP Address................. 192.168.11.12
Peer Redundancy Management IP Address............ 192.168.11.11
Redundancy Port IP Address....................... 169.254.11.12
Peer Redundancy Port IP Address.................. 169.254.11.11
management                       LAG  30       192.168.11.10   Static  Yes    No
redundancy-management            LAG  30       192.168.11.12   Static  No     No
redundancy-port                  -    untagged 169.254.11.12   Static  No     No
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: wlc ha maintenance mode
In order to use a WLC that has a license as an HA WLC, you need a minimum of a 50 AP license.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml
If you want to convert any existing WLC as a Standby WLC, do so using the config redundancy unit secondary command in the CLI. This CLI command will only work if the WLC which is intended to work as Standby has some number of permanent license count. This condition is only valid for the 5500 WLC, where a minimum of 50 AP Permanent licenses are needed to be converted to Standby. There is no restriction for other WLCs such as the WiSM2, 7500, and 8500.
-Scott
1 REPLY
-Scott
1249
