WLC in HA Keep Rebooting
I have a 5508 WLC pair setup in HA SSO mode and the primary controller keeps rebooting, while secondary is up and running.
We had to take power off the primary, so we first made switchover by issuing redundancy force-switchover. Then powered primary off and after putting power back it just gets up and then reboots.
Found the Peer. Starting Role Determination...
Restarting system ..
Does anyone have any idea how to resolve the situation?
Here is whole story from CLI.
WLCNG Boot Loader Version 1.0.16 (Built on Feb 28 2011 at 13:14:54 by cisco)
Board Revision 1.3 (SN: FCW1650L0H6, Type: AIR-CT5508-K9) (P)
Verifying boot loader integrity... OK.
OCTEON CN5645-NSP pass 2.1, Core clock: 600 MHz, DDR clock: 330 MHz (660 Mhz data rate)
FPGA Revision 1.7
Env FW Revision 1.8
USB Console Revision 2.2
CPU Cores:  10
DRAM:  1024 MB
Flash: 32 MB
Clearing DRAM........ done
Network: octeth0', octeth1
  ' - Active interface
  E - Environment MAC address override
CF Bus 0 (IDE): OK
IDE device 0:
 - Model: STEC M2T CF 1.0.0 Firm: K1367MIX Ser#: STIM2MA212285221848
 - Type: Hard Disk
 - Capacity: 977.4 MB = 0.9 GB (2001888 x 512)
Press <ESC> now to access the Boot Menu...
Loading primary image (7.4.100.0)
100%
34603060 bytes read
Launching...
init started: BusyBox v1.6.0 (2010-05-13 17:50:10 EDT) multi-call binary
starting pid 821, tty '': '/etc/init.d/rcS'
Set PLX switch MPS settings .............!!!!!!!
Detecting Hardware ...
set smp_affinity for irq 48
003f
DP from CGE5.0 ...
starting pid 1067, tty '/dev/ttyS0': '/usr/bin/gettyOrMwar'
Setting up ZVM
Exporting LD_LIBRARY_PATH
Cryptographic library self-test....passed!
XML config selected
Validating XML configuration
Read HA Config before validation
octeon_device_init: found 1 DPs
readCPUConfigData: cardid 0x6070001
Cisco is a trademark of Cisco Systems, Inc.
Software Copyright Cisco Systems, Inc. All rights reserved.
Cisco AireOS Version 7.4.100.0
Firmware Version FPGA 1.7, Env 1.8, USB console 2.2
Initializing OS Services: ok
Initializing Serial Services: ok
Initializing Network Services: ok
Initializing Licensing Services: ok
License daemon start initialization.....
License daemon running.....
Starting Statistics Service: ok
Starting ARP Services: ok
Starting Trap Manager: ok
Starting Network Interface Management Services: ok
Starting System Services: ok
Starting FIPS Features: ok : Not enabled
Starting Fastpath Hardware Acceleration: ok
Starting Fastpath Console redirect : ok
Starting Fastpath DP Heartbeat : ok
Fastpath CPU0.00: Starting Fastpath Application. SDK-1.8.0, build 269. Flags-[DUTY CYCLE] : ok
Fastpath CPU0.00: Initializing last packet received queue. Num of cores(10)
Fastpath CPU0.00: Init MBUF size: 1856, Subsequent MBUF size: 2040
Fastpath CPU0.00: Core 0 Initialization and FIPS self-test: ok
Fastpath CPU0.00: Initializing Timer...
Fastpath CPU0.00: Initializing Timer...done.
Fastpath CPU0.00: Initializing NBAR AGING Timer...done.
Fastpath CPU0.01: Core 1 Initialization and FIPS self-test: ok
Fastpath CPU0.02: Core 2 Initialization and FIPS self-test: ok
Fastpath CPU0.03: Core 3 Initialization and FIPS self-test: ok
Fastpath CPU0.02: Received instruction to get link status
Fastpath CPU0.04: Core 4 Initialization and FIPS self-test: ok
Fastpath CPU0.05: Core 5 Initialization and FIPS self-test: ok
Fastpath CPU0.06: Core 6 Initialization and FIPS self-test: ok
Fastpath CPU0.07: Core 7 Initialization and FIPS self-test: ok
Fastpath CPU0.08: Core 8 Initialization and FIPS self-test: ok
Fastpath CPU0.09: Core 9 Initialization and FIPS self-test: ok
Starting Switching Services: ok
Starting QoS Services: ok
Starting Policy Manager: ok
Starting Data Transport Link Layer: ok
Starting Access Control List Services: ok
Starting System Interfaces: ok
Starting Client Troubleshooting Service: ok
Starting Management Frame Protection: ok
Starting Certificate Database: ok
Starting VPN Services: ok
Starting Licensing Services: ok
Starting Redundancy: Starting Peer Search Timer of 120 seconds
Updating license storage ...  Done.
Restarting system.
Board Revision 1.3 (SN: FCW1650L0H6, Type: AIR-CT5508-K9) (G)
Everyone's tags (1)
VIP Purple
Not sure but i think you are
Not sure but i think you are hitting a BUG.
https://tools.cisco.com/bugsearch/bug/CSCud78928
I think you are running 7.4.100.0 version, try to upgrade to 7.4.121.0(Its a pretty stable version.)
Dont forget to rate helpful posts
Hall of Fame Super Gold
Duplicate posts.  :P Go here:
Duplicate posts.  :P
Go here:  http://supportforums.cisco.com/discussion/12152756/wlc-ha-keep-rebooting
82
