Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WLC limit per RF Group
Per Cisco documentation, it states that RRM supports a maximum of 20 controllers and 1000 APs per RF Group.
If I configure more than 20 WLCs with the same RF Group name, will the WLCs automatically divide themselves into 2 separate RF Groups or will this limit cause the 21st WLC to just not join the existing RF Group?
1 ACCEPTED SOLUTION
Silver
Re: WLC limit per RF Group
It will not allow 21st controller from joining the existing RF group. You have to manually put them in seperate RF group.
Silver
The controllers will automatically split into two RF groups (or more if they see fit, obviously, if APs do not hear each other).
Bear in mind that RRM tasks the controllers quite a bit from the memory and processor side. Having large numbers of multiple groups could cause reporting issues to WCS.
250
