WLC not pass DHCP past bridged units
Roger Smith
I have a WLC 5508 with LWAP 1242 with wireless bridges connected to the APs I cannot get DHCP to pass through the bridge to the PC connected to the bridge.
Some third-party WGBs need  to operate in non-DHCP relay mode. If problems occur with the DHCP  assignment on devices behind the non-Cisco WGB, use the following  commands:
config dhcp proxy disable
config dhcp proxy disable bootp-broadcast disable
The default state is DHCP proxy enabled.
the above commands introduced from 7.0.116.0.
5 Replies 5
Stephen Rodriguez
what type of device is your wire'ess bridge?  is it configured to be a universal workgroup bridge?  Do you have the passive client feature enabled? (requires 7.0 code)
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70wlan.html#wp1391015
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Thanks for the reply let me update the code and i'll get back to you.
I turned that on that did not help the bridges are HP ProCurve M111 Client Bridge
That fixed it thanks for the help
