10-26-2009 08:05 AM - edited 07-03-2021 06:11 PM
we have a WLC 4400.
Is the following possible?:
We want to have a html-site (with regulations) at which end should be an Accept-Button. After a click on that button, the user should be forwarded to the internal Web Login Page.
It's equal for us, if our own html-site is located at the wlc directly or at an external web server.
Is there any command like "dir flash"??
Thank you for an answer.
greetings L.
Solved! Go to Solution.
10-26-2009 09:10 AM
There are a number of variations available for the default guest user login page that can be modified with your logo etc available here
You will need a login to access this.
The default page in the controller and modified pages generally have the acceptable use policy and login details along with the accept button on the same page
10-26-2009 09:10 AM
