12-04-2009 08:03 AM - edited 07-03-2021 06:19 PM
I have to set up a wireless network using 802.11n. I was wondering if the 4.2 version is the best one? Is there any document that tells wich version to use depending on the the configuration we need to set up, for example?
jr94
12-04-2009 10:58 AM
If you are going to stick with a 4.2 train I would go with 4.2.207.0. That is the latest version of 4.2 which has the most bug fixes. Just keep in mind if you are going to use 1140's you will need to run a 5.2 or 6.0 version since they were not supported until these versions.
12-05-2009 07:26 AM
As Dan pointed out. ONLY 1252s will work on 4.2.x code!
12-06-2009 11:58 PM
Thanks for your replies. I know that I will only be able to manage 1252 with that version, and it is the model of my AP, so it is ok. But I was wondering if I should better use 4.2 or another train of releases. As 802.11n has been released on 9/11, I do not know if 4.2 is the best one.
jr94
12-11-2009 03:22 PM
802.11n is supported on the 4.2.207.0, 5.X and 6.X firmware releases. I personnally would stay away from the 5.X releases due to the amount of bugs.
