02-17-2009 10:50 AM - edited 07-03-2021 05:11 PM
I'm a bit puzzled by the documentation for the WLC concerning the service-port interface.
In the "WLC and LAP basic configuration example" documentation it is said: "If you do not want to use the service port, enter 0.0.0.0 for the IP address and netmask."
But in the "WLC Configuration Best Practices" it is said: "Do not leave an interface with a 0.0.0.0 address, for example an unconfigured service port. It might affect DHCP handling in the controller."
So, can I leave 0.0.0.0 on the service port or not?
Seb.
02-17-2009 11:10 AM
That is difficult to say. The best practices rule infers dynamic interfaces whereas the service interface is a physical one. Also, not all services are available on all interfaces.
why do you not want to use the service port?
02-17-2009 01:55 PM
Don't rule out the service port. This could save you if and when your WLC starts having a spasms.
I don't know with others, but I use the service port as a remote out-of-band-management in case the management IP should somehow fail. Saved me several times in the past.
02-18-2009 12:22 AM
thanks both for the answers.
We are using the console port of the wlc for remote OOBM. In our case i don't see the point in putting up anything on the service port in terms of configuration.
I merely wondering if we still have to configure it or not. We see some "DHCP-3-BIND_SRPORT_ERR" (service port binding errors) and documentation was indicating that it may be due to problems with the service-port.
