WLC SSID restrictions
Can you restrict an SSID to only be broadcast by specific Access Points?
Everyone's tags (1)
1 REPLY
VIP Purple
Yes, it is simple.  You have
Yes, it is simple.
You have to create an AP group & add the WLANs you want advertise by AP in this group. Then add  required AP to that AP-group, so only APs in that group will advertise the SSID configured in that group.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-5/config_guide/b_cg75/b_cg75_chapter_01011011.html
Rasika
*** Pls rate all useful responses ***
85
