wlc sudden reload
I have cisco WLC 5508 running version 7.4.110.0,
that WLC suddenly reload without any failure log left
there is no configuration changed in 1 day before that sudden reload
is there anyone who have problem like mine? need suggestion for resolving
any suggestion will be highly appreciated
thanks
regards
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
There are bugs with 7.4.110.X
There are bugs with 7.4.110.X codes which can cause the WLC to reload.  Upgrade to 7.4.121.X.
thanks for your suggestion
thanks for your suggestion Leo,
could you give me some reference about that?because i can't found any bug related to 7.4.110.0 version on cisco bug seacrh
thanks
regards
Go and read the Release Notes
Go and read the Release Notes for 7.4.121.X and the document will mention several "silent crash" bugs.
thanks a lot Leoregards
thanks a lot Leo
regards
Thanks for taking the time to
Thanks for taking the time to rate our posts.  laugh
81
