WLC Upgrade 7.4
Dear All,
I would like to upgrad my WLC's code to 7.4 from 7.0.
I want to know whether the new code has support for AIR-LAP1231G-E-K9  or not.
Thanks in advance.
Shijo.
  • Other Wireless - Mobility Subjects
2 ACCEPTED SOLUTIONS
VIP Purple
WLC Upgrade 7.4
Hi Shij,
7.4.x version supports these APs:
1522, 1524PS, 1524SB, 1552E, 1552H, 1552I, 1552C,  1552EU, 1552CU, 1552S, 1130, 1240, 1250, 1260, 1600, 2600, 3500e, 3500i,  3500p, 3600e, 3600i, 1140, 600 OEAP, AP801, AP802
1231 AP does not supported by anything higher than WLC code 7.x
Hope it helps.
Please rate helpful post.
Hall of Fame Super Gold
WLC Upgrade 7.4
The final firmware support for 1230 is 7.0.235.X.
If you really need to have a 1230, then you'll need to run it on autonomous.
VIP Purple
WLC Upgrade 7.4
Hi Shij,
Hope it helps.
WLC Upgrade 7.4
176
