Community Member
WLC & WCS - who was logged in...
I need to know which users used our wireless lan on sunday. To connect to the wlan they have to type in the wpa2 networkkey and then authenticate with username and password (web authentic.).
I could not find a logfile with this informations.
We are using WLC 4400 and WCS 5.0.56.2
Please help me,
greetings Lydia
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: WLC & WCS - who was logged in...
Hi Lydia,
Try this on your WLC ...
Management > SNMP > Trap Logs ...
Go to Client tab and put a tick on "Authentication". By default, this option is disabled.
Does this help?
Hi Lydia,
Does this help?
Community Member
yes it helps, mainly for the future because the Authentication-option was disabled and so I can't get information about last sunday. But referring to this I found out something with the "busiest client"-report.
Thank you.
Does this solve your issue?
Please rate when applicable and/or helpful.
Thanks for the ratings, Lydia.
163
