Community Member
WLC with WPA1 and WPA2 enabled
I have enable WPA1 and WPA2 on the WLC and My notebook support both WPA1 and WPA2.
Which one will be use when I connect to WLAN. How can I check if I am using WPA1 or WPA2?
Thanks.
C.K.
1 REPLY
Re: WLC with WPA1 and WPA2 enabled
Hi Friend,
When you check both the options one with higher security level will be selcted intelligently by the client which mean WPA2 will be selcted. If you configure both AES and TKIP, AES with WPA2 will be used.
Beacons will advertise both the encryption types. You can check the client details from the controller.
Ankur
204
