WLC2006 and AP-1010 Problem...... pls help to solve
hi all,
I could not get the WLC 2006 to communicate with the AP1010. My configuration is straight forward.
WLC2006----CE500----AP1010
DHCP Server (192.0.2.222) also connected to the CE500. The DHCP server can ping the WLC2006 and likewise.
configuration for WLC2006 is as below:
1. management IP: 192.0.2.24
netmask: 255.255.255.0
Management Int Default router: 192.0.2.222
Management Int VLAN ID: 0 (untagged)
Port: 1
Management Int DHCP Server IP: 192.0.2.222
AP-manager IP: 192.0.2.25
Port: 1
Virtual IP: 1.1.1.1
WLAN SSID: cisco
WLAN ID: 1
Interface Name: Management
This is a pretty simple and straight forward config. THe attached AP1010 initially has the power LED showing green color and then after few seconds, there are no more lights on all the LEDs. But the Ethernet interface is blinking green. Tried both PoE and External power, still the same. I tried using using the AP1030, and i did have all the LED keep on blinking.
It seems that the WLC2006 could not communicate with the AP. Can anyone help me solve this problem?
THanks a lot....
1 REPLY
Re: WLC2006 and AP-1010 Problem...... pls help to solve
I believe this may have been caused by the DHCP configuration itself whereby I didnt specify any Option 43 ascii parameter to point to the controller IP.
I haven't try this out yet but will try this out soon. Anyone can verify that this is the problem?
THanks
104
