Hall of Fame Super Silver
WLC2006 Can I use multiple ports
I want to seperate the guest interface by using ne of the other ports on the WLC2006. Is this possible or do I have to trunk everything on the port I have configured for management and ap-manager. I have port 1 as the management and ap-manager, but I want to use port 2 as the guest inteface.
-Scott
Silver
Re: WLC2006 Can I use multiple ports
Thanks for the feedback. Howerver, what I found out is that on the 2006 you can only configure 1 port for ap-manager so there is now way to seperate your dynamic interfaces. I know you can do it on the 4402 and the 4404, but I thought you can on the 2006.
-Scott
173
