WLC2006 internal DHCP
I am looking for help setting up the internal DHCP server. It keeps telling me the scope network and mask are incorrect. I have tried various setting and have looked around for a cfg example.
My MGMT int is 10.96.30.10
AP-MGR is 10.96.30.15
The scope and AP mgr interface can be any ip range, i do not need anything specific.
I have been trying 10.96.30.20-30
on network 10.96.30.10 / 255.255.0.0
Also does the 2006 support layer2?
Silver
Re: WLC2006 internal DHCP
I recommend to use external DHCP server, according to below link. There is DHCP relay issue if WLC as a DHCP server.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008070ba8f.shtml
Moreover, the 2006 supports LWAPP layer 3 only. The 44xx supports layer 2 & 3.
More info. from Q&A :
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a008064a991.shtml
Hope this helps.
thank you. i was putting the Netwrok address in incorrectly.
148
