WLC4402 connect to non-cisco switch?
I have 2 WLC4402-50 connected to an Extreme Black Diamond chassis, using GLC-T. I have configured LAG on the controllers to support the number of AP's needed and I have configured the ports on the switch to use LaCP aggregation because that is what is available. Is this a supported configuration or do I just need to leave those ports as non-LaCP ports?
  • Other Wireless - Mobility Subjects
Gold
Re: WLC4402 connect to non-cisco switch?
The controller doesn't support LaCP or PagP. You just need to configure the port channel statically. Also make sure the load balancing algorithm using for the port channel is source/destination IP. That is the only algorithm the controller supports.
not really sure how to do a static port channel without a protocol... I guess I will look into it.
just to help out anyone else using extreme, here is how I got it to work
first I define the src-dst ip load sharing like this
Switch#. configure sharing address-based L2_L3_CHK_SUM
and then I configure sharing on the ports (the port number between the sharing and grouping is just the master port number for the share)
Switch#. enable sharing 3:26 grouping 3:26, 3:56 algorithm address-based
Switch#. enable sharing 3:28 grouping 3:28, 3:58 algorithm address-based
and then I do the vlan config like
Switch#. create vlan "Wireless"
Switch#. configure vlan Wireless tag 250
Switch#. config vlan "default" add ports 3:26, 3:28 untagged
Switch#. config vlan "Wireless" add ports 3:26, 3:58 tag
216
