WLC4402 does not respond to HTTPS on the Management interface
Hi I have a 4402 running 4.2.205 (have tried 4.2.207 &4.2.176 also). i have this wlcconnected to a 3750 switch (no config - all ports in native vlan1 only g1.0.1 is a trunk for the wlc) vlan 1 has an ip of x.x.x.1/24 - wlc has an ip of x.x.x.2/24 on management interface. running layer2 mode - virtual interface is 1.1.1.1 - then i have a pc connected to the switch with ip x.x.x.10/24. when i connect to wlc using https://x.x.x.2 - it gives a page saying "problem with certificate" (this is normal) when i select continue to this website - the browser just sits there for hours??? if i give the service port an ip of y.y.y.1/24 and connect the pc directly with ip y.y.y.2/24 - https works fine?? What am i missing??
  • Other Wireless - Mobility Subjects
Re: WLC4402 does not respond to HTTPS on the Management interfac
Hi, also had browser access problems when upgrading from 4.1.185 to 4.2.176.
You may be hitting one of the following:
CSCsg66040-After a software upgrade, controllers might experience intermittent access to the management interface through HTTPS.
Workaround: Follow these steps to workaround the issue:
a. Make sure HTTPS is enabled on the controller's management interface, reboot the controller from the CLI, and monitor the last service if error messages appear after the controller prompts you to enter a username and password to login.
b. Login with the relevant credentials and reconfigure the virtual interface with this CLI command:
config interface address virtual 1.1.1.1
c. Reboot the controller and make sure the Secure Web service shows up as OK.
d. Generate a certificate using this CLI command:
config certificate generate webauth
e. Click Yes when prompted and wait a few minutes for the certificate to generate.
f. Reboot the controller.
or
then the problem may be your browser that is trying to connect with SSLv2 and that may be disabled on the controller. Try the cli command
config network secureweb cipher-option sslv2 enable
Gustavo
Hi Gustavo,
I've tried all that ;-(
here is a capture of the settings
(Cisco Controller) >show certificate summary
Web Administration Certificate................... Locally Generated
Web Authentication Certificate................... Locally Generated
Certificate compatibility mode:.................. off
(Cisco Controller) >show interface summary
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
ap-manager 2 untagged 200.200.200.3 Static Yes No
management 2 untagged 200.200.200.2 Static No No
service-port N/A N/A 100.100.100.1 Static No No
virtual N/A N/A 1.1.1.1 Static No No
(Cisco Controller) >show network summary
RF-Network Name............................. testrfg
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Enable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Mode..................... Disable Mode: Ucast
Ethernet Broadcast Mode..................... Disable
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
ARP Unicast Mode............................ Disabled
Cisco AP Default Master..................... Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Over The Air Provisioning of AP's........... Disable
Apple Talk ................................. Disable
--More-- or (q)uit
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
802.3 Bridging ............................. Disable
any other ideas??
I've used the service port to config it, but it won't authenticate AP's either
some error messages;
Mar 1 00:00:43.781: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
examining image...
*Sep 10 14:49:37.174: %LWAPP-5-CHANGED: LWAPP changed state to IMAGE
*Sep 10 14:49:37.256: LWAPP_CLIENT_ERROR_DEBUG: spamProcessSecureMsg : spamCcmDecrypt returned failure
*Sep 10 14:49:37.256: LWAPP_CLIENT_ERROR_DEBUG: spamProcessImageData : spamProcessSecureMsg returned error
*Sep 10 14:49:38.160: LWAPP_CLIENT_ERROR_DEBUG: spamProcessSecureMsg : spamCcmDecrypt returned failure
*Sep 10 14:49:38.160: LWAPP_CLIENT_ERROR_DEBUG: spamProcessImageData : spamProcessSecureMsg returned error
thanks for any help ;o))
Have you tried to regenerate the self signed certificate?
If not, no more ideas...
Gustavo
225
