WLC4402 - No keyboard input via console
ERIK BOSMANS
I try to configure a WLC4402 new out of the box. If I make a console connection for initial configuration I see the boot sequence in my terminal software but I am not able to send keyboard commands. the session does not accept keyboard input. I tried to do this with different PC's, different serial ports and different cables, including the supplied console cable. I have been testing with other devices (cisco router on console cable) and with these devices everything works fine. Only the WLC4402 gives me trouble. Any advice? Thank you.
dancampb
Level 7
Level 7
Make sure that flow control is disabled on your terminal emulation program.  Having flow control enabled will cause the exact issue you are describing.
dancampb
Level 7
Level 7
That is the solution. Thank you.
