10-20-2013 08:35 PM - edited 07-04-2021 01:07 AM
Has someone ever found this kind of error.
I try to disable many unallowed clients in system myself. But the only client name 88308ADDF9A2 can't be removed.
Please suggest me a solution.
Thank you.
Solved! Go to Solution.
12-30-2016 12:28 PM
Just as an FYI,
If you use the search by Mac address and put the mac all in Capital Letters you will find the mac address that you are looking for but with no description on it and you wont be able to delete that client from the exclusion list, so the work around is to use lower cases on the macs while searching or look for the client manually if you want to use the GUI or use de CLI, I think this is a Bug and I have seen it in all software versions.
regards.
Example:
But Client STILL show in Client list
To solve this just use lower case in the search box.
Leo Mtz
10-20-2013 10:26 PM
You disabled his client manually? or it get excluded by other means (multiple auth failures for example)?
Does this MAC address appear in the exclusion list?
> show exclusionlist
Amjad
Rating useful replies is more useful than saying "Thank you"
10-20-2013 10:31 PM
Amjad,
Yes I need to push him out my network like this
So let me check ' show exclusionlist '
Nipat
10-20-2013 10:50 PM
so, it is disabled already? but you are not able to remove it?
or it is not disabled and you are trying to disable it? I am confused.
10-20-2013 11:34 PM
Correct, it is not disabled (STILL show in Client list) and I'm trying to disable it. Then error shown.
10-20-2013 11:53 PM
Good.
So, you may try the CLI commadn to exclude the client:
config exclusionlist add
That should work.
You need also to make sure that your client list is updated. the first error message says the client is disabled and it is no longer on the system.
with the "show exclusionlist" you make sure if it is disabled or not. if not, you use the CLI command to exclude it.
Amjad
10-21-2013 02:58 AM
Amjad, You're right. Solve with CLI configure.
10-21-2013 03:26 AM
Great. glad to hear that.
Please mark the thread as "answerd".
Amjad
12-30-2016 12:28 PM
Just as an FYI,
regards.
Example:
Leo Mtz
04-20-2021 12:49 PM
Thanks!!
It works for me, I was searching by Uppercase, just change to lowercase and works well.
