12-29-2005 11:36 AM - edited 07-04-2021 11:27 AM
Hey guys,
I need some clarification. Is WDS mandatory for WLSE??
I have a client with 120+ AP's and they are using WEP (ugh, i know) between their phones and the AP's. Can I take two of these AP's and configure them as WDS?? If so, what do I need to do on the AP's??
Thanks much guys!!
01-02-2006 07:48 PM
You don't need WDS for WLSE to do config and firmware management, most faults, and most reporting. However, if you want to use the advanced solution features like radio management, rogue AP detection, wireless IDS, real-time client tracking, and fast secure roaming with 802.1x, you'll need WDS.
If you decide you want to go with AP-based WDS, you need to configure at least 1 AP per subnet to run WDS. That "subnet" refers to the management network for the APs. The max number of APs that can be supported per AP-based WDS is 60 and that assumes the WDS host is a dedicated device.
This document describes the configuration process:
HTH,
Jake
01-03-2006 03:02 PM
Thanks Jake, I think that answered my question.
01-05-2006 03:54 PM
Jake,
Do you know what gets backed up when performing a backup from the WLSE?? My client wants to be able to backup the backed up configs (backup the backup mentality) and I can't seem to find a clear answer online. Specfically, do the configs from the archive get backed up??
Thanks!!
-LLoyd
