Workgroup Bridge using LEAP
I am trying to setup an 1131AG (version 12.4.10b-JA) in Workgroup Bridge mode to connect to my wireless network, which is a Light Weight network (WCS version 4.2.81.0 and WLC version 4.2.112.0, the APs are 1131AGs in LWAPP mode). I am using LEAP for authentication. So far I've been pretty unsuccessful. The three popular error messages I seem to get depending on how I fiddle with things are:
%DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No matching privacy setting (from 001a.307c.0670)
%DOT11-2-UPLINK_FAILED: Uplink to parent failed: Unsupported authentication type
%DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No Cisco parent
The configuration on the WGB is as follows (using dot11radio0):
version 12.4
no service pad
service password-encryption
hostname ap
enable secret xxxxxxxxxx
no aaa new-model
dot11 ssid TEST
dot1x credentials LEAP_cred
dot1x eap profile LEAP_prof
power inline negotiation prestandard source
method leap
username isaironet
password xxxxxxxxxxxxxxx
username Cisco password xxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode wep optional
ssid TEST
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role workgroup-bridge
mobile station scan 2412 2437 2462
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.1.1.1 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
exec-timeout 60 0
line vty 0 4
login local
end
If any body has any ideas of what I'm doing wrong I'd really appreciate a point in the right direction.
Ben
Silver
Re: Workgroup Bridge using LEAP
The reason of the error is connection to the parent access point failed for the displayed reason. The uplink will stop its connection attempts
Benjamin, did you ever figure this out? I am dealing with the same problem right now using a 1231 autonomous AP as WGB. I'd actually like to configure it for EAP-FAST as opposed to LEAP, but can't find documentation that covers EAP-FAST. Only EAP-TLS.
Yes, I finally figured it out and it was the dumbest thing. The person before me who had configured our WLANs on the WLC disabled Aironet Extensions in the WLAN profiles. Apparently Cisco WGB can't connect without that being on... can't believe I over looked it, but glad I got it fixed.
The config I posted I believe is actually fine and you might be able to look at it and figure out what you need to modify to get EAP-FAST to work.
Thanks Benjamin. Glad you figured it out. When you say Aironet Extensions in the WLAN profile, are you referring to the IE (information element) check box under WLAN->Advanced configuration screen?
Yes, sorry, I meant the Aironet IE box.
3261
