Community Member
Workstations on Aironet 1100 AP cannot see each other.
Hi.
I have problem with Aironet 1100 AP where machines connected to this AP cannot communicate among each other (cannot ping). However, each workstation can ping the AP.
Also the AP can ping the workstations.
There are no firewalls between.
Arp table on AP looks ok and it has all devices attached.
Arp table on workstations have got only records for the AP.
Can someone help me how to resolve this?
Thank you
Hall of Fame Super Red
Re: Workstations on Aironet 1100 AP cannot see each other.
Hi Jiri,
Can you try disabling PSPF;
Enabling and Disabling Public Secure Packet Forwarding
Public Secure Packet Forwarding (PSPF) prevents client devices associated to an access point from inadvertently sharing files or communicating with other client devices associated to the access point. It provides Internet access to client devices without providing other capabilities of a LAN. This feature is useful for public wireless networks like those installed in airports or on college campuses.
Note To prevent communication between clients associated to different access points, you must set up protected ports on the switch to which your access points are connected. See the "Configuring Protected Ports" section for instructions on setting up protected ports.
To enable and disable PSPF using CLI commands on your access point, you use bridge groups. You can find a detailed explanation of bridge groups and instructions for implementing them in this document:
•Cisco IOS Bridging and IBM Networking Configuration Guide, Release 12.2. Click this link to browse to the Configuring Transparent Bridging chapter: http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fibm_c/bcfpart1/bcftb.htm
You can also enable and disable PSPF using the web-browser interface. The PSPF setting is on the Radio Settings pages.
PSPF is disabled by default. Beginning in privileged EXEC mode, follow these steps to enable PSPF:
Command Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
interface dot11radio { 0 | 1 }
Enter interface configuration mode for the radio interface. The 2.4-GHz radio is radio 0, and the 5-GHz radio is radio 1.
Step 3
bridge-group group port-protected
Enable PSPF.
Step 4
end
Return to privileged EXEC mode.
Step 5
copy running-config startup-config
(Optional) Save your entries in the configuration file.
Use the no form of the command to disable PSPF.
http://www.cisco.com/en/US/docs/wireless/access_point/12.2_15_JA/configuration/guide/s15rf.html#wp1038494
Hope this helps!
Rob
Community Member
Hi Rob.
Thank you very much. This worked fine. I am quite new to Cisco so I didn't know this. I though it is going to be some sort of Wireless Isolation as it is so called in other low range APs (eg. Linksys).
Thanks for this. Really appreciate this.
Jiri
Hi Jiri,
You are most welcome!
Take care and welcome aboard :)
Rob
Green
Happy New Year Rob!
Good answer!
Scott
Thanks Scott!
Happy New Year to you too my friend :)
Take care,
Rob
1158
