Axis P3343-VE Cameras
We are currently running VSMS ver 6.0.0.  Will I need to update to 6.3.2 in order to use this camera, or is there a separate camera driver/module download I can use?  Thanks.
Re: Axis P3343-VE Cameras
hi Nathan,
Axis P3343 is not on the supported list of devices . I just check the supported devices list for VSM 6.3.2  &  DO NOT see P3343 listed in the supported devices.
You will need to have a driver written for this, please contact your Cisco Account reps and they can assist you in the process.
Hope this helps!
Karthik
I see.  Thank you very much for the reply.  Where can I find a list of supported devices for vsms software releases?  I don't see anything in the release notes that I can find, or in software downloads.  Again, thanks for your time!
hi Nathan,
Here you go...
http://www.cisco.com/en/US/docs/security/physical_security/video_surveillance/network/media_server/6_0/user_guide/vsms.pdf
Search for "Axis" in the pdf for the list of supported devices of  Axis.
Hope this helps!
Karthik
572
