Cisco IP Camera 2521V view rotation
Is there a way to rotate view on Cisco IP camera 2521V 90 degrees left or right?
I couldn't find that option under GUI web interface. Also I couldn't find it under VSOM.
2 ACCEPTED SOLUTIONS
This discussion has been
This discussion has been reposted from Cisco On Demand to the Physical Security community.
Silver
The 2521V is a fixed dome
The 2521V is a fixed dome camera. i.e. - Not motorized or PTZ.  It *may* be possible to acquire the shot you want, but would require someone 'unbutton' (open) the dome and manually manipulate the gimbal assembly and set screws.
There is a broad shouldered set screw that locks the circular imager assembly in place.  (While keeping an eye on the slack/tortion on the cable/wiring harnesses that connect this component) You should be able to rotate this assembly in either direction and re-seat the set screw.
All the best.  Cheers!
Scott Olsen Solutions Specialist Bulletproof Solutions Inc. Web: www.bulletproofsi.com
Silver
56
