CIVS-ES-16EC and Stream Connection Feature Licenses
Hi guys,
I'm trying to find out if I need stream connection feature licenses if I use CIVS-ES-16EC. The description of the capture board is telling me that some SW licenses is included (Cisco VS 16 Channel Encoder Card With SW License) but I don't know for sure what to think.
Thanks a lot for your help.
Alex.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: CIVS-ES-16EC and Stream Connection Feature Licenses
From Cisco, "The answer I got back from the contacts with the product series indicate that all the channel licensing needed for the CIVS-ES-16EC are included with the unit. They wanted me to make sure you were aware that the cabling parts are sold separately. The cable part to use is CIVS-CAB-ES-8EC and a quantity of 2 of those are needed to support all 16 ports."
Thanks a lot for your help mcwalter.
Alex.
507
