CPAM and Device I/O help
scottbob09
I am attempting to use an momentary on button on an input to trigger the unlocking of a door.
I have no problem doing this using global I/O
But when attempting to create a "local" device I/O rule, I can put in the trigger but then there is no action available for me to do a grant access on the door.
Any ideas?
Scott Thomas
wilchow
Level 5
Level 5
You should create a door template with additional Device Type=REX / Device Template= "Push Button Rex (NO)" and connect the button to the input you assigned. Please refer to CPAM_1.2 User Guide Page 5-22.
