After configuring Taccacs on 2960 switch still the same secret password are working. does anyone know what is the problem of this. Please see below for my configuration.tacacs-server timeout 15tacacs-server directed-requesttacacs-server key ------ta...
i have a problem with CPAM system. I have cisco gw reader with each door and when the door close/lock, it show status door forced open. I have check check the wiring and configuration still couldn't solve the issue. May i know is there anyone facing ...
Hello all, I have a location that is being closed temporarily, so no internet, etc. As such, I'm now getting spammed with the fact that the cameras are down by VSOM. I imagine if I had done the smart thing and disabled the cameras in VSOM prior to ...
can someone help me,i configure 2 cisco firepower 1010,1 for router and the other for firewall,i can get internet from router device when i plug the rj45 to router,but i cant get internet when i do to firewall,please help me,thank you
Hi to anyone that might bother to help,
As again i have spoken with the very unhelpful technical support from Cisco with no avail i would like to ask here.
My customer has 3 types of cisco cctv cameras
CIVS-IPC-3620, CIVS-IPC-7530 and CIVS-IPC-7070...
We have a Cisco ASA5525 with FirePower managed by an FMC (Virtual machine).In the configuration there is a reference to Management — Displays information about the communication channel between the Firepower Management Center and ”The device”; see Ma...
Hello,I have a situation where i can't grasp some things. I have a Router Cisco ISR 1k connected P2P via /30 public subnet.Behind the Router ISR 1k, i have a Cisco FTD(firepower3110) connected p2p on a /27 public subnet. I have used first 2 public IP...
Hi How do i know/ calculate threat protection throughput of Cisco firewall 4215?https://www.cisco.com/c/en/us/products/collateral/security/firewalls/secure-firewall-4200-ds.html Please suggest if "throughput: FW + AVC + IPS" is considered as threat p...
Good morning everyoneI need to apply an access list on the outside interface to allow reaching the servers in the DMZ and an access list with the control-plane suffix to mitigate some brute force attacks on the VPN. How can I do? It seems to me that ...
Hello everyone, I'm Abdelrahman and I'm new here. In fact I'm new to the world of networking and I need your help. I want to become a cyber security engineer. Now I'm studying CCNA. I need the right path to do this. What's next CCNA and what are the ...
Greetings,I have a new Firepower 2110 firewall, it was starting in Rommon mode, I had tried to boot from tftp successfully.But after which it restarts automatically.Attached is the output. It seems it is going under some error. Below is the message i...
Newer switches have the factory-reset all secure command which performs a NIST purge (see System Management Configuration Guide, Cisco IOS Release 15.2(7)E3k (Catalyst Micro Switch Series)I've just found this command but it doesn't work for older swi...
Hello to all, we are facing a problem with a number of gateways not being able to successfully connect to the CPAM server.On the server side we are able to locate the below:...2019-09-11 12:17:57,159 Thread-26 ERROR comm - comm.TransportContext : Err...
