issues with the bandwidth consumption for router 2811 and 2901 with IPICS solution
We have  IPICS 4.0.2 and would like to know if any of you have problem with integration of router RMS and LMR in the same router
the proble is when we have router 2811 the bandwidth consumption is greater at difference the bandwidth consumption for a 2901 roter.
in reality the interfaces of the routers 2811 and 2901 are different in the 2811 the interfaces are Fastethernet and in the 2901 are GEthernet , but the interfaces in both case is the same result:
I noticed that the traffic generated for the 2811 is greater at difference of the 2901 as see in the interfaces:
2901 interfaces:
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is d0d0.fd76.a1e0 (bia d0d0.fd76.a1e0)
  Description: link to  XXXXXXXXXXXXXXX
  Internet address is XX.XX.XX.XX/xx
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 5/75/0/0 (size/max/drops/flushes); Total output drops: 2
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  5 minute input rate 23000 bits/sec, 23 packets/sec
  5 minute output rate 23000 bits/sec, 23 packets/sec
     2702768 packets input, 366237389 bytes, 0 no buffer
     Received 20951 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     2900046 packets output, 383056409 bytes, 0 underruns
     0 unknown protocol drops
     3 lost carrier, 0 no carrier, 0 pause output
2811 interface
FastEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 18ef.6347.d310 (bia 18ef.6347.d310)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Input queue: 5/75/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 485000 bits/sec, 250 packets/sec
     41309150 packets input, 1232495052 bytes
     Received 32 broadcasts, 0 runts, 0 giants, 0 throttles
     2 input errors, 0 CRC, 2 frame, 0 overrun, 0 ignored
     0 watchdog
     643401943 packets output, 3440311538 bytes, 0 underruns
     0 lost carrier, 0 no carrier
is assumed to be the same traffic with the two routers different.
Any ideas?
1015
