07-23-2014 03:25 PM
What's the difference between Prime Collab Deployment (PCD) and Prime Collab Assurance and Analytics or Prime Collab Provisioning??
PCD contains all 3 applications??
Juan Carlos
Solved! Go to Solution.
07-23-2014 09:04 PM
Hi Juan,
Basically, Prime Assurance ,Provisioning and PCD are three different applications.
PCD is used for migration of Call Manager clusters from version 6, 7, 8 to version 10 on VM servers.
Assurance is used for real time monitoring of devices like IP phones, Gateways, get inventory reports.
Provisioning is used for Day 2 support for managing users[ add , delete , change]. Users can do forward, speed dials , change passwords.
regds,
aman
07-23-2014 09:04 PM
Hi Juan,
regds,
aman
07-24-2014 12:03 PM
Hello Aman, thanks for your comments.
